It's Jason's can-do attidude.What's Jscan?
Dad joke out of the way...it's a diag tool.
see here - https://static.nhtsa.gov/odi/rcl/2026/RCRIT-26V363-8818.pdf
photos of what the techs are to look for
If it were my Jeep, I'd look at the connectors and it they looked good I would go on your trip. If it looked like the suspect connectors, I would have to think more.
99.44% chance yours is good...I called to schedule an appointment for My oil change and see if they could do the recall inspection while it was there. I was told that if they do the inspection and find a problem, they can’t release my vehicle to me. Which didn’t seen correct to me, it’s my damn jeep. How can you not release it? She said it’s a safety issue.
My friend called the dealership. They said bring it in we will look at it and if it looks bad we will have to keep it until we get the parts in to make repairs. Parts should be arriving mid September. He didn’t take it in.
So I called to see if they could check out the recall while they were doing the oil change. I was originally told the same thing that if they found a problem, they could not release my vehicle back to me. That seemed insane to me, it’s my vehicle. I was told it was a safety issue., I was told to wait and I will be notified when they have parts available before they inspect it. So fast-forward a few days, I take it in for the oil change and I’m talking to the service guy about what I was told on the phone. He said we cannot keep your Jeep, it’s your vehicle. We will inspect it while it’s here and if it needs to be repaired, we will call you when the parts are in, but you will leave with your Jeep. He said, we’ve done probably 500 inspections so far and not one has failed. So you’re probably good. Mine was inspected and all came back good. So don’t let them tell you they’re gonna keep your Jeep. They cannot!Yeah, I would not take it in either. Who knows when parts will be available.
NiceSo I called to see if they could check out the recall while they were doing the oil change. I was originally told the same thing that if they found a problem, they could not release my vehicle back to me. That seemed insane to me, it’s my vehicle. I was told it was a safety issue., I was told to wait and I will be notified when they have parts available before they inspect it. So fast-forward a few days, I take it in for the oil change and I’m talking to the service guy about what I was told on the phone. He said we cannot keep your Jeep, it’s your vehicle. We will inspect it while it’s here and if it needs to be repaired, we will call you when the parts are in, but you will leave with your Jeep. He said, we’ve done probably 500 inspections so far and not one has failed. So you’re probably good. Mine was inspected and all came back good. So don’t let them tell you they’re gonna keep your Jeep. They cannot!
Considering there is a 58 page tech procedure on what needs to be done it's fairly intense depending on what they find, if you do have the problem and the pump and harness needs to be replaced your probably looking at 2 days (and that is if the parts are in stock) The tech is allocated .3 hours simply for the inspection and nothing else, it goes up from their depending on what they find.Apologies if this has been covered, but:
1) What will the repair entail? Upgraded harness and pump?
2) Has this issue been addressed on new builds, such as late 2026, or yet to be built 2027? I can't imagine they'd continue to build them without addressing it?
3) Will the repair be better than some of the aftermarket upgrades that are out there, such as the Apex and PSC versions? If not "better," at least rendering these upgrades less of an appeal to the owner?
Do you have an idea of the weight difference between the v6 and our v8 ? Toss in the diesel if you’re up for it thanks ,The original power steering gear in the 2018 JL was designed at the max to be used with 33 inch tires, and a lightweight V6. Not 35 and larger like 37's and 40 plus the extra weight of the 392. In all honesty I am amazed it does as well as it does.
Steering, cooling, transfer case and differentials used in the 392 are for the most part at the absolute limits of their design limitations.
As a result we are beta testers for the platform. An in all honesty I think the reason Jeep hasn't announced the 392 Gladiator. That application will push the platform over the edge as it will be expected to tow at least 7k, and have a curb weight much higher then the Wrangler.
For us Wrangler owners these short comings are just something we will need to deal worth. We can thank or fellow Wrangler owners who push the envelope of current design and use their Jeeps to the extreme. They really discover the weak parts before we general owners ever know about it!
Thanks for posting that link. My Jeep has been converted to a full PSC system, so I had been wondering if I still need to take it in for an inspection. I looked at the pictures in your link and then looked at my Jeep. None of the parts they are inspecting are in my Jeep anymore, so no inspection is needed.see here - https://static.nhtsa.gov/odi/rcl/2026/RCRIT-26V363-8818.pdf
Yes. Power steering pump would overheat and then lose function.Had my 2024 Wrangler 392 checked out at the dealer today. They inspected some wiring harness and said it was fine. This might be unrelated but my power steering pump overheats almost every time I go offroading but I haven't had any issues beyond the warning light. Has anyone actually had an issue with the power steering system on trail besides the warning light?
Also converted to PSC system. However, it’s unclear, at least in CA, if an open safety recall will interfere with DMV registration, which may still necessitate an inspection unfortunately.Thanks for posting that link. My Jeep has been converted to a full PSC system, so I had been wondering if I still need to take it in for an inspection. I looked at the pictures in your link and then looked at my Jeep. None of the parts they are inspecting are in my Jeep anymore, so no inspection is needed.
