Performance exhaust button - No difference in sound on/off?
You think so? I had looked at it and figured it's something else. No idea what a solenoid looks like but I was picturing something bigger :ROFLMAO:
It’s a switch so it usually looks like a small plastic black box in automotive uses
Hey all, let me preface this by saying I've had the thing for about 10 days and I have 2010 miles on it, solid mix of highway and around-town driving, both aggresive and super easy-going. I have also read the manual (and the 392-specific manual addendum pamphlet thingy) about 20 times to make sure I'm not crazy. No cluster lights or alerts either.
I can't for the life of me hear a single difference between the two modes when I press the performance exhaust button. I've let it idle for 5 minutes and tried the button, I've tried the button while driving very very easy on the throttle, I've tried the button when going slow, I've tried the button going highway speeds, I've tried the button with the top and doors on/off. I hear zero difference. After driving around for 20 minutes or so, I've gotten out while the thing is idling and gone behind it, and in a blind test of a buddy turning the button on and off, I cannot detect a tone change whatsoever.
Let me also add that I do a lot of sound-sensitive professional audio monitoring and if there was a tone change, a timbre change, a decibel change, or any sound characteristic change whatsoever, I sure as hell should be able to pick it out! The way people talk about the feature in casual posts, it sounds like something's not working properly on mine, since they report being able to hear an obvious enough, (if subtle), difference when the button is pressed.
I'm thinking that if it's stuck in either position, it's stuck open/loud/"on".
I have an appointment at the dealership next week for them to look at it, but wanted to see if anyone else had experienced an issue like this, or had been able to find threads where someone else experienced something similar. Also if someone's a wizard and has a fuse chart handy, if there's one of those I should check, or if I'm missing something absurdly obvious.
Thanks!
I have had mine since jan 24 and notice a big difference. In any drivind situation. It quiets down a good bit whenever I turn it off. I noticed when you get on it it opens up in either position
