PARKSENSE UNAVAILABLE WIPE OFF REAR SENSORS
I have a low milage 2023 XR and I weekly get the “PARKSENSE UNAVAILABLE WIPE OFF REAR SENSORS” pop up in dash. But not every day?
My Jeep is garage kept and always clean.
Stock bumper and stock 35" spare tire.
Warning will usually appear, when I shift into reverse, after diving short run (15 miles), in FL with perfect weather, no rain. Don't get warning when I first start out, only after a short trip.
Other times I get no warning?
I've checked and sensors are perfectly clean.
Fuses are fully seated, however I question that theory because a fuse will make contact wether fully seated or not?
Jeep has a firmware update coming out for that... any day now.... any... day....
I don't get the message, but it alarms EVERY time I put it in reverse. Not much sense of even having it.
Thanks, I'll watch out for update.
Do you know if update will be pushed through Uconnect or dealer flash?
Rotate the tire on the carrier so that the TPMS sensor is further away from the backup sensors. I believe there’s info about that in this forum and also the JL forum. For what it’s worth, I put the reinforced tire carrier on mine and rotated the tire on the carrier and haven’t had any additional false alerts.
Now that I think about it, I did recieve an update through uconnect thats when the problem started right after that, hopefully there will be a follow up update to the last update..
Thanks I read about that too, will give that a try..
What seemed to solve my sensor issue was changing the Mopar tailgate reinforce bracket to the Teraflex HD carrier and mounting bracket. It allowed me to get the tire very close to the tailgate. This is a 37x13.5. My TPMS is at the 3 o’clock position. My sensors were completely useless before all this.
Thanks, I appreciate the feedback
Has anyone solved the parking sensor issue , I just added 37 inch tires with 2.5 lift on jeep 392xr and have parking sensor issue too
could have sworn it was my exhaust on humid/cold days... now you make me wonder. Coincidence after you put those on?
I have a 392 XR with factory XR wheels, and want to go to 37's with no lift. What tire size and model did you go with if I might ask, at the risk of going off topic.
BFG ko2 37x12.50r17 with xr wheels
This parksensor is referring to the sensors in the bumper not the rear wheel
I did notice today that factory mounted my spare with the valve stem/tpms at bottom, 6:00 position.
I will rotate tire to have tpms at 12:00 position?
Some as 2:00 position??
Any reason for 2:00 position?
I rotated mine around to near 12:00 and never had another false alert.
I did a spare tire delete and I still get the parksense when reversing... for me it's the exhaust, not the tpms setting something off.
Mine aren’t beeping at all. I just get this error message after the jeeps been on for 5-10 seconds (see attached). The tpms I’ve heard could interfere but the spare is mounted so the tpms is as far as it can be from the bumper. I thought it might be the tazer so I unmarried it - no dice there either. If I unplug a sensor I get a different error message saying to service the park sense system so I can tell the car is reading the sensors. I’m stumped.
Today I had this exact issue. (The Rear Park Sense Unavailable Wipe Sensors). I wiped all sensors, took to car wash still had the issue. I remounted the spare with the TPMS at 1000 on the tire mount instead of the 0500 that it was. The issue went away ..... so far. Is this possible? Is there a better fix? Thanks.
I have had this parksense warning/light issues sporadically for a while now and really didn’t think much of it. Sensors are always clean, fuses appear well-seated. I took her in for an oil change at the dealer today and they pulled the codes. I had a stored code for parksense sensors short to ground. Service advisor suggested I schedule a service appt to check it out but they are a month out. I declined and may investigate this on my own and see if it’s still a problem at next oil change. Obviously there is a short-nicked wire, moisture issue? I dunno…. I also have a weird active code for head unit button stuck. I have a touchscreen. Go figure.
I get that head unit button stuck after eating BBQ out here in Texas. If you leave a lot of sauce on the touch screen it keeps registering a "button press". A bag of wipies in the glove box solved the dilemma. I'm just kidding of course. Interesting regarding the short-to-ground. I have the park sense thing, but only on cold days when the exhaust moisture fogs the rear sensors.
The funny thing is I get this same error occasionally even with a spare tire delete set-up. For me it's definitely exhaust condensation that gets on the sensors on some days, not others...
Update on Parking Sensor not working, So I took the spare Tire off and Parking Sensor worked with no problem...It is safe to say that my issue is the TPMS interfering with parking sensor...
Reactions: B92
