PARKSENSE UNAVAILABLE WIPE OFF REAR SENSORS
I honestly suspect they are exceptionally sensitive to condensation vapor in the exhaust.
I had this issue last winter, no issues all summer, and now happening just as the temps are dropping again. No other changes.
Also noticed, it doesn’t happen after the engine and exhaust are up to operating temp.
Mine aren’t beeping at all. I just get this error message after the jeeps been on for 5-10 seconds (see attached). The tpms I’ve heard could interfere but the spare is mounted so the tpms is as far as it can be from the bumper. I thought it might be the tazer so I unmarried it - no dice there either. If I unplug a sensor I get a different error message saying to service the park sense system so I can tell the car is reading the sensors. I’m stumped.
Drive with the spare completely off and see if that does anything. If not it might be worth a negative battery removal for a bit and see if all of the computers reset. If that doesn’t fix it… dealer.
I thought about the dealer but with my aftermarket wheels, 37’s, and Motobilt bumpers I know what the dealer is going to say…
Did you take some WD40 or isopropyl alcohol to a rag and the four sensors?
This error is reflecting the four sensors located in the rear bumper, not the rear sensor in the mounted wheel. They’re small circles. One is shown here:
Do you have the non XR factory tire carrier?
Yes; cleaned them all multiple times
Ah ok. Just wanted to be clear given the talk of the wheel.
I will echo the times (maybe a few weeks) this error was popping for me was up north in Chicago during winter to the other poster here theorycrafting weather as a culprit.
It’s warranty work, If it sticks around I’d have them check. You have to un mount the bumper and the sensors are expensive…
Fwiw I’m running 37 BFGs the Jeep hinge reinforcement and took the camera cover off the spare wheel instead of trying to flush it up further.
Sorry can’t be more help. Best of luck
Thanks. I’m looking at probably just shutting them off through the Tazer
You should consider keeping them on just to see if it clears and report back in case you can identify what is going on/solution…just a suggestion.
That and it’s got the cross sense traffic sensor there - someone can correct me here, if I’m wrong on that… anyway, it’s a handy bonus of the modern vehicle I figure.
Edit to say after my last windshield SafeLite couldn’t get the whatever-it’s-called that auto brakes and is responsible for adaptive cruise control calibrated. It
can also be disabled via the Tazer and the settings menu in the jeep console.
But now it’s off until I have a dealer fix it. They send me emails about it. Jeep and Safelite both now.
Maybe I’ll get it working for liability but that system especially in the Wrangler seems dodgy at best.
Hard disable for me.
Look at all the bikers killed by Teslas — Tesla drivers* — this year. Watch the road, be an active driver….
Preaching to the choir, I’m sure…
Blind spot detection (sensors located in taillights) and park sense (sensors located in bumper) are two different features and can be independently disabled by the Tazer.
Hey on the bright side I won’t have annoying beep beep beeps when I back up. But this is regardless of whether I disable or not… disabling just allows me to not have to stare at an error message telling me to wipe my sensors every time I go in reverse.
I have a teraflex alpha
Do you also have the Teraflex hinge reinforcement? My sensors were crazy with just the Teraflex tire relocation but when I changed out the tailgate reinforcement to Teraflex it allowed me to push the spare tire closer to the tail gate, I haven’t had a sensor issue since then. That being said, I wasn’t getting that same warning message, just crazy sensors in reverse.
Yes I have both. The working theory here is the tire is too low and needs to be adjusted higher. I feel I was having this warning before the tire was even put on as I ran it without the spare for a period of time. The shop is standing by their work and taking a look at it next week
Just picked up my 392 yesterday and got the same message! Hadn't even made it 50 miles!
I’ll drop this here once more then I’m checking out on this particular thread.
I run a 35 on a stock carrier.
I saw this issue last winter, and wondered if it was due to the density of the air (moisture) emitting from the exhaust. Over the summer, the only thing that changed, was the moisture coming out of the exhaust. All summer long, no reverse warning issues with the sensors. As soon as the weather dropped, first cold morning start up, guess what? Reverse sensor giving a warning.
I also did an impromptu test run in reverse. When I throttled up, enough to move the vehivcle and get the “fog” to roll under the chassis, the warning sensors stopped. When I stopped, it came back on.
It’s my theory. Only because the vehicle is designed to accept 35’s. And, it been intermittent, relative to the moisture emitting form the exhaust.
Spent some time troubleshooting. Removed the spare tire, adjusted all 4 sensors with zip ties in the BA bumper to make sure they were pointed straight and not down or loose etc.
fired her up this am and it’s decently chilly…. Got all the lights and warnings going off without there being anything behind the jeep.
Took a photo of what I think is the culprit as has been said here a few times:
I have an XR with 37's. This happens to me all the time no matter how clean. I'm used to it by this point
Has anyone solved the parking sensor issue , I just added 37 inch tires with 2.5 lift on jeep 392xr and have parking sensor issue too
