TheBeast23
- Feb 16, 2023
- 288
- 309
- Current Rides
- 2011 WK2 JGC Limited 5.7 Hemi / 2022 WL74 JGC Summit Reserve 5.7L Hemi
Was your 392 smoking and exhibiting similar conditions as noted in the post you attached?
Mine only burned about two tablespoons during the first 1500 miles. Now no drop on dipstick all seems to be tight. This includes off roading steep trailsIt’s a good habit to get into, this way, at a minimum, you can monitor if it’s short of your last fill; your vehicle could be burning oil (or has an unknown leak).
When I remember I check the dipstick before draining.It’s a good habit to get into, this way, at a minimum, you can monitor if it’s short of your last fill; your vehicle could be burning oil (or has an unknown leak).
When the oil if fresh it takes good light and a few try’s to see that level and usually have to put the dipstick back in 180 just to be sure.When I remember I check the dipstick before draining.
As mentioned in that thread: I noticed a very small amount of smoke twice during startup over the two month ownership period since acquired new at dealer. Minor enough I wouldn’t have even mentioned it had I not noticed the thread started by another member.Was your 392 smoking and exhibiting similar conditions as noted in the post you attached?
Exactly - The dipstick “should” indicate if the oil is low, full or overfilled above the hatches if “PROPERLY” checked….When I remember I check the dipstick before draining.
Yep.Exactly - The dipstick “should” indicate if the oil is low, full or overfilled above the hatches if “PROPERLY” checked….
ROUGHLY 5 +/- quarts overfilled should definitely show in some capacity that it’s above the proper fill lines on the dipstick…as well as oil PSI fluctuations on the gauges….This is alarming to me that there “seems” to me no indication in the scenario that was started in this post.
Amsoil Signature, oem weight /viscosity. I've used Amsoil in all of my vehicles for years.What oil are you guys running that are doing your own oil changes?
That’s what Mopar sells I use it because of that. 10 bucks at dealership about $7 to8 on AmazonI've just received my 2024 392 so no oil change yet, and I don't know about other Model Years, but the MY2024 Owners Manual specifically recommends to use SAE 0W-40 meeting MS-A0921:
Not all of them say MS-A0921 on the back label. Here's one that I found:
FWIW.
My guess is it would just look full that oil was probably very clean and transparent hard to see on dipstick. Easier to see when oil is getting dirty or a little bit darker.Just curious as to what it was reading on the actual dipstick “BEFORE” you changed the oil as this sounds insane and really bad for the vehicle at ANY mileage - Also extremely curious as to your “OIL PSI” readings before the oil change during your break in mileage with this much oil in the engine![]()
By chance did you get any test results back yet?Yep.
And when checking a new vehicle, you’d look to see if it’s “full”. Which I, and most others do.
I don’t think mentally anyone is considering evaluating/analyzing over “full”.
It looked new (gold color), and “full”. I didn’t over-analyze it.
Not yet. Sent them off a week ago today. I’ll post results once I receive.By chance did you get any test results back yet?
ThanksNot yet. Sent them off a week ago today. I’ll post results once I receive.
Exactly.
What’s crazy is 95% of oil changes likely aren’t measuring out what was drained.
(E.g. I have a feeling this was a similar situation: https://www.jeep392.com/threads/occasional-smoke-new-2024.3324/
As I mentioned, many simply take to dealer to utilize their free wave program, or a quick lube, where they simply drain the oil, and add the recommended 7.5 quarts. All unaware of a factory overfill issue. (And some running up to 5k miles on initial factory fill)
