For those that responded and also for anyone that might end up with the steering issue I had.
(Problem) My Jeep was pulling left. After 2 dealership alignments and a third party alignment stated everything was within specifications - Their only recommendation was to keep tires rotated. No other suggestions as for a fix.
Here was the solution that worked in my case and below are the notes for my repair:
Work performed by Mike's Off Road in Haltom City Texas.
Mike and his crew really made the problem a good learning experience. He was willing to spend time on the phone in an attempt to diagnose the problem before bringing the Jeep in.
Didn't just say I don't know to get me out of his hair.
Replaced the lower control arms with Mopar part number 68322798AA to obtain more caster.
These replacement Mopar control arms added 1 degree of caster above the factory installed arms.
Also installed - a caster cam bolt kit to adjust caster split so to allow correction for my pull to the left.
Final alignment and then a test drive to confirm the installs worked properly.
Success.
I mentioned in another post above that there was a gentleman dealing with a similar issue here in another thread on the forum. He mentioned that his dealership service department stated the solution to his problem was an aftermarket caster bolt that would be covered under factory warranty. To me it sounds like it may have been a similar fix. Fortunately for him his dealer service department at least had knowledge of the problem and a possible solution. Both of my local dealer service departments knew nothing of this.
Im driving straight again
