- Thread starter
- #21
That........is......the......test......of.........tests ! KudosView attachment 25383I’m at 22,000 miles and use my exclusivity for off-roading.
For the T-case, the TrailRecon guy is the only person that I have heard of that has experienced a failure… I chalk that up to bad luck or being in the wrong 4-wheel drive mode… possibly with an overweight trailer. This should be easy to warranty or replace with an aftermarket upgrade.
- T-case has not been an issue.
- Hot steering was an issue AND I could barely steer when I engaged my front lockers.
- While off-roading, my Jeep has completely stalled on me, many times, when I have less than than 1/2 a tank and I’m headed downhill.
- Jeep has replaced everything, between the gas pump and the gas tank, and it still will stall!
- Almost crashed a couple times and Jeep still hasn’t figured it out!
IMHO, the steering on the 392 cannot handle the weight of a 37” tire. This is disappointing because my old 2019 JLUR had the same wheels and tires on it, never overheated, and I could still steer when I used my front lockers! I added a PSC when I moved to 40’s and 1 tons.
As far as it stalling, I suspect that this is a software issue to possibly protect the fuel sending unit or they need to add another sending unit in the front of the gas tank. It is absolutely ridiculous that a Jeep can stall with 1/2 a tank of fuel on as little as a 15 degree slope. Assuming Jeep never solves this issue, I’ll eventually replace the fuel tank when I do a 4-link in the rear.
When the Jeep stalls on a down slope, will it start back up on the slope or do you have to drift to the bottom first ?
