guruman
- Joined
- Nov 16, 2022
- Messages
- 985
- Reaction score
- 1,853
- Location
- Montana/Indiana
- Current Rides
- 2023 Rubicon 392 20th Anniversary Edition, 1996 M1078 rolling fortress
- Thread starter
- #61
Today's adventure....
2 classics there in that last pic…
Once they meet the Belgian Malinois... they will leave on their own accord... if they can.I enabled the homelink buttons to work before I start it
That might be a security risk when the Jeep is not garaged: if a thief breaks the Jeep he/she can open the garage door and potentially get in your house.
I did this on mine right after Thanksgiving. I had a harder time putting the skid plates on them than installing the sliders. Trying to get the rivet holes lined up and be able to get the bolt holes on the bottom lined up. And then once I had everything started, the middle bolts underneath took me a while to get tightened up because there is hardly any room to move between the slider /skid and the frame and also took a bit to get the right combination of socket, extension and rachet that would fit. Still could only rachet a couple of degrees each time. I was doing it without lifting it up though, so don't know if it would have been easier if I would have put it on the lift instead.I still have the external skids to bolt on.... that'll wait for another day. Hopefully it's a bit easier than this whole dance of getting the steps and wiring down.
I were a drinking man, I'd need a drink.
Well, that's not encouraging at all. Thanks for the heads up.I did this on mine right after Thanksgiving. I had a harder time putting the skid plates on them than installing the sliders. Trying to get the rivet holes lined up and be able to get the bolt holes on the bottom lined up. And then once I had everything started, the middle bolts underneath took me a while to get tightened up because there is hardly any room to move between the slider /skid and the frame and also took a bit to get the right combination of socket, extension and rachet that would fit. Still could only rachet a couple of degrees each time. I was doing it without lifting it up though, so don't know if it would have been easier if I would have put it on the lift instead.
