Donor for Hybrid Transfer Case?
Jmos4
Imlay City MI
2026 Jeep Willys 392
Hi,
Just doing research, but what donor works to make a hybrid transfer case with no clutches?
Will one from a standard 2.0 or 3.6 work or does it need to be a specific model?
Regards,
Jim
You would use your case MP3022C and purchase a transfer case out of a 2.0/3.6 JL MP1622C with the 2:72 Ratio.
If you wanted a 4:1 case you would need a transfer case out of a 4XE and a Rubicon case out of a 2.0/3.6 Rubicon.
Hi,
Just wanted to be sure, as my luck I would get the one combo that wouldn't work.
Regards,
Jim
I would go to https://parts.allmoparparts.com/ and look at part numbers for the 2026 2.0/3.6 Rubicon and see it the part numbers are the same as earlier models. I would guess that they would be. Or go the parts department of your local jeep dealer and they could look it up for you.
