ValB
- Joined
- Apr 24, 2021
- Messages
- 40
- Reaction score
- 27
- Location
- Lake Tahoe, NV
- Current Rides
- 2021 392 Jeep Rubicon
Has anybody seen a way around the 99 mph speed limit yet?
Thanks, I will take a look at it!2021-2023 Jeep 392 Diablosport/Holley Tune features and capabilities w/ Link to PCM Cross Ship
You must first do this to get PCM: https://www.holley.com/products/tuners_and_programmers/pcm/parts/PREAUTH-PCMwww.jeep392.com
That limit is there for a reason. And it is not arbitrary. Not for your safety since most these days don’t care about others. There are things on your Jeep that are speed rate limited to 99, like your tires….Has anybody seen a way around the 99 mph speed limit yet?
Yes sir mine are "T" Rated...https://www.firestonetire.com/tire/destination-at2/P285-70R17/#section-tech-specsThat limit is there for a reason. And it is not arbitrary. Not for your safety since most these days don’t care about others. There are things on your Jeep that are speed rate limited to 99, like your tires….
I believe this is the only way.2021-2023 Jeep 392 Diablosport/Holley Tune features and capabilities w/ Link to PCM Cross Ship
Set your tire size to be 28” and you will be going a lot faster than your Speedo thinks. This is something not to do a lot as you zf8hp75 will not like it.I believe this is the only way.
Let me think this out, I actually think you have to set it to a larger size to be going faster than the speedo thinks. But yes, that is a way.Set your tire size to be 28” and you will be going a lot faster than your Speedo thinks. This is something not to do a lot as you zf8hp75 will not like it.
Not to correct you, but remember switching to bigger tires? Your speedo reads low. Smaller tire setting with bigger tires installed equals lowers speedo reading.Let me think this out, I actually think you have to set it to a larger size to be going faster than the speedo thinks. But yes, that is a way.
Correct, I was thinking backwards. Sorry.Not to correct you, but remember switching to bigger tires? Your speedo reads low. Smaller tire setting with bigger tires installed equals lowers speedo reading.
Use a taser to change your tire size to 50”! Will still stop at 99 but you would be going a lot faster! HahaHas anybody seen a way around the 99 mph speed limit yet?
Yes but a tuner is only $400...View attachment 27031
Problem solved, it will handle a lot better as well.
^^ How to say you have a lot of money without saying you have a lot of money! HahaAs much as I love high speed driving, NO WAY would I want to get into triple digits with a Wrangler.
I’ll stick with my Lamborghini Diablo Roadster or Ford GT for that purpose, they are both engineered and rated for 200+ mph driving.
“Passive brag”^^ How to say you have a lot of money without saying you have a lot of money! Haha
Nope, what I do have is the ability to set a goal, make a plan to meet the goal, and keep working at the plan until the goal is reached.^^ How to say you have a lot of money without saying you have a lot of money! Haha
RespectNope, what I do have is the ability to set a goal, make a plan to meet the goal, and keep working at the plan until the goal is reached.
Took my 9 years to save up to buy the Diablo and 6 years to buy the FGT. For a middle class Engineer that meant hundreds of hours in overtime each year, and taking in side work.
So if you consider 15 years of sweat equity a humble brag, go right ahead, I’m proud that I met these goals without spending a dime of my regular paycheck.
