🤯 ULTIMATE Wheel & Tire Photo Thread...
@Smess
This is a link to the manufacturer’s catalog https://www.hutchinsoninc.com/rock-monster-wheels/ . The vehicle column lists the vehicle applications in red. There is an 8.5” and 9” version for the JL. The offset and backspacing are slightly different (see chart).
I bought from Northridge 4x4 https://www.northridge4x4.com/part/...utchinson-rock-monster-beadlock-wheel-package . They were familiar with the proper product numbers.
It is important to confirm with your intended lift manufacturer to verify their backspacing requirements for functionality and fitment. I.E. Metal Cloak, If using aftermarket wheels on the 392 with their 3.5" lift the backspacing required is a maximum of 4.75".
@Smess
Thank you!!!!
I got my Rock Monsters from Northridge 4x4 as well. I believe they are still running the sale buy 4 get 1 free. Think I’m going to buy another set for my JK
Coming in late in the game here, but here are some photos of my wheels and tires, Hutchinson RockMonster 17x8.5 with Goodrich 37x12.50x17 KM3s
s
Jl Rubicon and some models have different length axles than the JK so they will stick out more than a JK.
Was referring to bolt patter. Axle length/offset can be used even if not ideal but bolt pattern without an adapter........
Which muffler protection plate is that? Difficult to install? Great looking 392!!
Thank you, the skid plate is by Rock Hard 4x4. Fairly easy install, very precise fit between the frame rails. I was able to install it my self with the help of a small floor jack with a crossbeam attached. Rock Hard has a video on how to install their skid plates. I posted my experience on one of the other threads here on the forum.
Looks great! Which black lug nuts did you use with the Hutchinsons? Looks like they might be the gorillas but wanted to check. Installing mine soon and trying to figure out black lug nuts to go with
Thank you! They are in fact Gorilla Lugnuts along with a Gorrilla lock nut. There may be an alternative to consider with the lugnuts contained in the photo.
We own two of these monsters. A 2021 392 all black and now a 2023 also all black. They're both non-XR. Carbon copies of each other. Gave the wife the 2021 and I took the new 2023. Just put 37s on the 2023, and while there were some fitment issues initially, they're great now, and I think they look better than the 35s on 18s that are on the 2021. Went with Mickey Thompson Baja Boss AT 37x13.5x20 on Fuel Flame 5 matte black 20x12s with a -44 offset and 4.79 backspacing, no spacers needed. Be advised, these are out past the fenders quite a bit. No keeping this thing clean. The tires don't rub inside the fenders, but at full lock they were contacting the rock rails and the front bumper ends. Didn't like the rock rails anyway so I swapped them for the N-Fab cab length podium nerf side steps, and I deleted the end caps on the bumper, and it looks far better than it did. The N-Fab steps are quite a few inches shorter than the rock rails which worked out perfect. Added 2" JKS bump stops in the back just in case, but I have no clearance issues unless I really wheel the thing. Have the tailgate reinforcement and swapped out the tire carrier for the Teraflex oversized carrier. 37 fits fine on the back and does not contact the bumper. Looks outstanding, and I love the sky one touch top. Here she is...
Saw this Jeep north of Tampa yesterday.
Jeep with Orange wheels.... 04:04:23...webp
Recently switched my 35x11.50 tires to 37x12.50 Nitto Trail Grappler M/T tires. Hutchinson Rock Monster Wheels 17x8.5 backspacing 4.63
I have a non-XR looking to simply add 35x11.5's (Toyo or Nitto) to my stock rims. I do wheel it hard, as I guess you do too. Any rubbing off-road with simply adding 35x11.5's? And is a Tazer a must have to correct once stepping up, even if I am fine with speedo being off?
I have Nitto Ridge Grappler in 35 x 12.50. No issues whatsoever. Many have done this. If you are fine with the speedo being off I guess you dont need the Tazer but it does a lot of things I like.
I used the AEV ProCal Snap JL to program my tire size since I have no interest in any of the other functions of the Tazer.
Also I have Falken Wildpeak A/T3W 35x12.50r17 and no rubbing on my non-XR.
Same as the rest, I’m running 35x12.5 Cooper STT pro but mounted on Hutchinson Rock Monsters. Fully flexed out no rubbing and I’m still running uncalibrated with no issues. There is no ride height difference between the XR and none XR
Thanks Mouse. Your wheel offset, likely wider Rock Monster rims, and inch thicker tire change the equation, but I appreciate your input and still gives me an idea. I want to stick to 11.5's for the rim width (just one of those guys). I love the Cooper STT pros, and wish they came in the size tire I want.
