Utah Design Foundry Stubby Bumper Closeout Panel
QQ - I have the OEM bumper ends on, however, I still don't like to see the part behind the fog lamps + Connector/ wiring harness exposed to the elements.
Will these still fit if I have the ends on the front OEM bumper still installed (as it came from factory)?
Honestly I’m not sure. I’d test it but I don’t have the mopar bumper anymore. I’m curious though. DM me and I’ll send you a set to test if you want
Quick shout out to Ryan at Utah Design Foundry, after I installed his stubby bumper close out panels I reached out to him about a panel to close out the rear bumper for those of us with fender chops…he delivered. Affordable quality product as usual.
Thanks for sharing Ben! Glad ya like them
Sold. Sipping coffee on a Sunday morning. Now I don’t have to keep looking back at that void with the dang fog light wires staring at you..✌️
Fabricated my own (I have access to a press brake). Need to cleanup the outer edges....OEM bumper.
Hello. Was this ever finalized? Do the covers work with the bumper ends not removed? I needz to know! Thanks!
I held the end caps up to mine…I think it might fit with the plate installed, then the end cap put over it. The only problem might be the length of the screws not being long enough. Ryan said he would send a set out to you to try them out. PM him.
Interesting. Thanks. I saw that he had offered a set to someone to test out. I was hoping he actually did and could report his findings. I'll shoot him a pm. Thanks!
Anyone have issue installing these Utah Design Foundry Stubby Bumper Closeout Panels?
I tried installing mine and would not fit flush, 1/2" gap from fitting flush against back of factory steel bumper, contacted back of factory LED fog light plugs, both sides.
Are you guys just forcing them on, crushing wires at back of plug?
Mine is 2023 XR stock bumper and lights.
I see many have installed these cover plates and I haven't heard any issues?
Any chance mine has odd light plugs or do they look normal?
No issues. Did you apply the foam seal around the edge how the instructions show?
I added pics. I do have the foam seal but still won't close the gap.
I showed to my local Jeep service manager and he thought it would be too much pressure on plug wires, on mine.
How can I be the only one??? lol
Here’s a look at mine… slight gap at the top but not huge.
I read someone else had this issue and they called support on it and were told that due to manufacturing tolerances some have this issue and they just have to use some washers to space it out. Supposedly the newer kits come with them in case you need them. I haven't gotten them, but have thought about it a time or two.
Here’s a closeup on the back of my fog light… it is very tight
Washers spacing is a good idea, thanks. Was considering slightly bending mounting points?
I wasn't sure if Jeep had a run with different fog light plugs?
Someone posted a link to these stubby bumper panels from Utah Design Foundry and I ordered right away. They took about 2 minutes to install and look so much better. Powder coated aluminum that matches the bumper in texture with a rubber gasket that the user sticks on. Sometimes it's the small things that make the final touches so nice. Highly recommended. Installs with factory hardware but if you lost your hardware after removing the bumper ends they can send you a new set also.
View attachment 21248View attachment 21249View attachment 21250
Clean
