So today I got the dreaded service 4 WD drive light. This is the second time it happened.
The difference is the first time, 3+ months ago , it was in my drive way while reversing to my parking spot which proved to be a struggle.. turned off the car and went to sleep, next morning everything good.
Today it happened when stopped at traffic light. Drove off almost normal. Then had the chance to stop at gas station turned off and back on. The light came back. Then turned off for while longer. Then the light went off. But the wheels are binding when turning into a curb and backing off is hard. Drove home and tried to switch the offroad plus but the ESC did not switch off like it it should normally do.
Went home and disconnected the battery for about an hour. Then test drove it and the problem is the same, without the dashboard light.
Anyone experienced the same? Is my T-case broken. The car has 39000 km only!! And barely offload, two dry easy drive in the sand, it is a pavement queen ….
