prodriquez
In all seriousness, most shops just want to sell you parts based on your budget rather than discover your needs, goals, and performance expectations… which is an extremely expensive and often frustrating journey.
To me, it sounds like you have a good build but you’re carrying too much weight for your springs and your shocks simply cannot compensate for the difference. I also suspect that a 2.5” lift is not enough lift for the type of wheeling you want to do and the lines that you want to take.
My advice is to drive some other jeeps and get a feel for how they handle/perform while on-road and off-road.Here are some 392 suspension lift height generalizations to consider:
If 2.5” of lift works for you… I would replace the springs, with a heavier duty spring, and I would hold off on replacing the shocks until you have an opportunity to evaluate their true performance. Alternatively, buy some King Coilovers and go completely custom
. I’ll recommend Filthy Motorsports out of Boulder, Co. if you want to go the custom route. I have no affiliation… just respect
- 2.5” lifts will be optimized for OEM weight and on-road handling characteristics. They are not optimized for off-road use but they will accommodate a 37” tire. They are great for occasional off-road use without sacrificing (much) on-road performance.
- 3.5” lifts strike a balance between on-road and off-road performance. This lift offers higher clearance and can accommodate up to a 39” tire and is ideal for the weekend wheeler that wants to do moderate to severe trails (6 to 9 rated).
- 40’s and extreme lifts are loaded with trade offs… so I will simply say that nothing on the Jeep was designed to handle a 40. Do your own homework and I’ll encourage you to check out some of my previous posts on this topic.
