Hey
@Lancet03 I did remove the SOT this summer. Here are some tips and tricks for anyone who is interested in doing the same:
Tips and Tricks for removing the Sky one Touch top (SOT)
Can you remove the SOT? Yes, absolutely. It's just 22 bolts and 4 parts to take it off (Roof, back glass and 2 side windows).
Brandon Haneline already has a great video detailing the process.
The biggest issue is storage. The windows are easy to keep in the included storage bag but the roof panel is big and kinda heavy, and the back window is awkward and everything is painted and easy to scratch. I built an electric driven hoist in my garage for the roof using
Harkin hoist I had laying around. This also required some framing and swapping the garage door opener to a side mounted unit to keep the roof hoist area clear. For the back glass I built a storage box out of parts from the box the soft-top came in. This is defiantly a process I would just do at the start of summer and then go back to the SOT at the end of summer.
Once you take out the 11 bolts on each side holding the roof down it is easy to lift off. There are 2 index pins on the back and front of each side that help align the roof for installation. If your wanting to instal the soft top like I did you have to remove these pins on the front L & R side to be able to latch the soft top closed. Each side has a small bolt under the visor that needs to be removed and is easy to overlook. You'll end up with 9 bolts per side which I put into a foam block to keep them organized.
Next to remove the rear glass you remove some plastic covers to access the 2 bolts holding it to the body tub on each side but you need to be vary careful because once you remove the bolts the only thing holding it in place is a few alignment pins. On the driver's there is an electrical disconnect and the washer fluid disconnect. I wanted to attach the loose hoses somewhere but there is no connection bracket on SOT jeeps. So I bought the plastic cap and just left it hanging down there.
With everything off you'll end up with 22 bolts total. When I reinstalled them I was super careful with the torque on the fiberglass, only used about 7 N m of torque even though I had read that up to 12 N m is ok. So now I wanted to install my soft top.
Tips and Tricks for installing a factory soft top on Sky one Touch top (SOT) jeep.
Can you instal a factory soft top on a jeep that came with a SOT? Yes, absolutely! First I had to remove the front SOT Index pin using a set of 10mm and 16mm wrenches. Now you need some parts. You'll need a Jeep JL Wrangler windshield header trim part, you need to make sure its from a soft top jeep with the cutouts for the soft top latches, and if possible from a jeep with the forward windshield camera option. I got mine on eBay for $65. Then you'll also need a set of Mopar Front Latch Brackets (68290476AA & 68290477AA) (both driver and passenger side) with two bolts each. I got mine on eBay as a package for $40.
Now you have to modify the soft top windshield header trim to fit the SOT Auto Open/Close button. On the back of the trim panel the plastic has been molded to allow for this button to be installed but the trim needs to be cut out. This is a case for a Dremel tool and some patience. I made a tracing of the hole shape then went to work. The switch has a small bezel so it will hide some rough edges but the switch is flat and the trim is curved so it will not fit perfectly on the actual SOT trim piece there is a raised area that compensates for this curve. But it's close enough for Jeep quality.
View attachment 25141View attachment 25142
I didn't mess with the wire harness at all, just unplugged the trim components such as the SOT open/close button etc. After I was done cutting out the SOT switch I reinstalled everything just as the factory had it. With this new visor trim installed I can switch from SOT to a soft top and not have to make any changes. I added the half doors and I called it done. Honestly the SOT is so nice I am not sure I would recommend doing all this work, but if you need some summertime soft top Jeep in your life then this is defiantly doable.
I hope this is helpful!
