Service Axle Locker Light
fspalt09
Baltimore
Jeep 392
So this morning I was driving to work and on a left hand turn I got service axle light and the Jeep felt like it was on ice. Even though I had the wheel cranked left the jeep wanted to go strait. I pulled over turned it off and back on struggling to turn. I drove slowly down the road and after driving for a minute or so it went off and the steering went back to normal. I have the Tazer so I looked for a code and got C1416-13 coming from the DTCM (Drivetrain Control Module). Not sure if this is related to a wheel sensor or the locker sensor. I know many have had issues with the locker sensors shorting due to diff fluid seeping into the sensor but I thought that only symptom of that was the locker not being available and not any issues with normal driving. Any thoughts would be appreciated.
Here's a good explanation on a known problem:
I had this same problem on my 2018 JLUR. I pulled the sensor out, cleaned it with brake clean (it has a small hole in it that allows diff fluid to enter, blew it out with compressed air and potted it closing up the hole. Never had another problem. I believe this problem was fixed on the later JL Rubicons.
