It hasn’t shown up yet. Delivery by the 13thAny update and thoughts on the Oil Udder?
Does it seem to fit well and accommodate the angle and tight space for the filter? What about the larger filters?
TIA
TIA
I bought one as well. I'll be using it here in a couple of weeks maybe. My concern is that I usually use a filter wrench (socket?) on a long extension to get up in there to spin the filter off... the oil udder prevents me from doing that, and that may limit it's usefulness.The udder might be a winner. It’ll catch that annoying drip that’s starts on the back side of the filter when you crack it. I won’t try it for a few more months since I’m not set for an oil change for a bit
Ordered one.
I ordered one as well. I was able to get to screw into oil port. Had to tilt back a bit toward the windshield. It took a couple of tries to get the threads to grab but it did work for me.Ordered one.
Maybe a defect with mine, but will not screw into oil port.
Would not recommend.
I purchased one also and tried it. It worked for me. No issues.BarneyM said:
Screws in and seals great.
Lisle 19802
https://www.amazon.com/Lisle-19802-Threaded-Transmission-Funnel/dp/B000P0VTC8
Likewise I bought one of these as it was WAY less expensive than the other alternatives. I did have trouble the first time I tried to test fit it to the engine - had to tilt it back like someone else mentioned and IIRC had to kind of push down to get the threads to start but once they started it screwed in no problem. It now goes in easily and works great.I purchased one also and tried it. It worked for me. No issues.
Just did my first as well. Same thing. Filter on so tight it crushed before I could finally get it started. I also used the SRT filter as well.I just did my first oil change and here are some other notes.
First the dang factory filter was on WAY WAY beyond the torque specs. I did not have the socket type wrench that goes on the end and had to use a compression strap type of wrench and it actually crushed the can of the filter before it moved.
