Dallas911
- Nov 13, 2021
- 70
- 84
- Current Rides
- 2023 392 XR, 2013 JKUR, 2001 Porsche 911, 2025 Range Rover Sport
.....and it just died. Luckily I had a battery jump starter with me.
That is what I was figuring as well. Probably just going to swap it with a AGM 94R and call it good. It's not bad yet so I'll hold off for a few.
Good to know! We'll see how Florida treats it.AGM in my experience is not that good for harsh AZ heat. I went through several Odyssey Extreme (dual setup on a JK) at 1.5 to 2yrs a clip.
In the end a great battery warranty is a lot more important.
Weird, I have never had an issue with AGMs in Texas.AGM in my experience is not that good for harsh AZ heat. I went through several Odyssey Extreme (dual setup on a JK) at 1.5 to 2yrs a clip.
Curious how long before you replaced your OEM battery on your 392? At 30k and it seems like our '22's battery is not holding up as well as expected. I don't think it's the alternator / starter but it does take a few to crank up. Before I swap it, I'm just curious if we are the only one haha
Didn't had a problem per se, just expected those batteries to last longer.Weird, I have never had an issue with AGMs in Texas.
Any battery will last longer if on a battery tender when not driving. These new stock vehicles have a lot more battery draw when OFF than older stock vehicles had.
Stock 21’ battery took a s**t around 26,000mi. Under warranty so no big deal. However I noticed recently that my alternator was over charging to 15.2 volts which tripped the batt light. Turned off and back on went to normal, but happened twice. Check the alternator and verify proper output.Curious how long before you replaced your OEM battery on your 392? At 30k and it seems like our '22's battery is not holding up as well as expected. I don't think it's the alternator / starter but it does take a few to crank up. Before I swap it, I'm just curious if we are the only one haha
That's very interesting! In our case it was the battery as well. Still under warranty but with how slow Jeep dealers are in Florida, we can't leave ours there for a few days nor do we want to so I just bought one at cost and swapped it.Stock 21’ battery took a s**t around 26,000mi. Under warranty so no big deal. However I noticed recently that my alternator was over charging to 15.2 volts which tripped the batt light. Turned off and back on went to normal, but happened twice. Check the alternator and verify proper output.
considering the same choice as I have to get one tonight......will keep the other as a standby for accessories testing etc.....<-- 13k miles 1.5 years since delivery, went with optima yellowtop.
Mine is going on 4 years. Same batteryCurious how long before you replaced your OEM battery on your 392? At 30k and it seems like our '22's battery is not holding up as well as expected. I don't think it's the alternator / starter but it does take a few to crank up. Before I swap it, I'm just curious if we are the only one haha
Here is the one I bought: Holiday discount ends today.For those of you that put in an Odyssey battery what exact model did you use that fits? When looking at them on Napa’s website the Wrangler does not pull up any direct fit replacements in the Odyssey lineup unless I am overlooking it. No interest in modifying battery tray or cutting anything for replacement but would like to go as big as possible with the replacement.
I think I've seen your 392 cruising about town.Heat kicks your batteries rear. Im told it cuts the life in half here (Lake Havasu, AZ). That would be evey 2 years. Florida not much different I imagine?
