Cali392JL
- Joined
- Sep 21, 2022
- Messages
- 167
- Reaction score
- 160
- Location
- Los Altos, CA
- Current Rides
- 2022 White JL 392XR
Featured
- Thread starter
- #21
That is an awesome looking Jeep! Mine should be very similar when done, though I am using the stock extreme recon wheels powder coated good/bronze.
I am replacing the front driveshaft as preventative maintenance. The issue with the driveshaft is not with the lift height, but with the droop articulation. From what I've heard if you limit yourself to a 28.5 inch extended length shock you can live with the stock driveshaft for a bit. Your metal cloak system will allow lots of articulation. If you have the rocksport, shocks, they allow full droop and you might end up having a driveshaft problem. If you ever get into serious, off-roadIng where are you encounter full droop. What shocks did you end up going with?
