Falcon 392
The manual tells you to change it every six months no matter what.What if you don’t put any miles on it in 6 months?
It goes the other way too. Don't see it discussed often so a good reminder if you're using it off road it drops to every 4,000 miles.The manual tells you to change it every six months no matter what.
I hadn’t gotten delivery of the Jeep yet, so I was surprised that it was actually in the manual but not tied to the oil life monitoring system. I could probably write a software patch for that fairly quickly.The manual tells you to change it every six months no matter what.
The 350 hours makes sense. Any engine run time measurement makes sense. If I’m TDY in Afghanistan for 6 months and it doesn’t get driven (which is a shame, I know), then do I change the oil as soon as I get back home? Seems arbitrary based on my experience with equipment maintenance.It goes the other way too. Don't see it discussed often so a good reminder if you're using it off road it drops to every 4,000 miles.
For every person who says it doesn’t need to be changed, someone else can make a solid argument that it should.The 350 hours makes sense. Any engine run time measurement makes sense. If I’m TDY in Afghanistan for 6 months and it doesn’t get driven (which is a shame, I know), then do I change the oil as soon as I get back home? Seems arbitrary based on my experience with equipment maintenance.
The safest thing (and recommended) to do there is change the oil no matter what after 6 months, even if not driven. There are numerous threads, diagnostics, reports, opinions, etc on this topic in the forum and I encourage you to absorb all of it and form your own opinion and make your choice, but ultimately if the manual says it's required, just do it so you, your rig (and wallet) are protected.The 350 hours makes sense. Any engine run time measurement makes sense. If I’m TDY in Afghanistan for 6 months and it doesn’t get driven (which is a shame, I know), then do I change the oil as soon as I get back home? Seems arbitrary based on my experience with equipment maintenance.
Roger that. And it’s a good excuse to drink beer in the garage.For every person who says it doesn’t need to be changed, someone else can make a solid argument that it should.
Personally, I’d change it. Oil isn’t just about mileage or hours. Additives can settle, moisture can build up, and the oil can degrade over time even if the engine hasn’t been running. Six months sitting isn’t extreme, but it’s long enough that I’d rather start fresh.
To me, changing oil twice a year regardless of mileage is inexpensive insurance. It’s a small cost compared to the price of an engine, and it removes any doubt.
As mentioned in my other thread, my MDS lifters were shot right from the factory, but they're getting fixed now under warranty. This whole experience has really opened my eyes to how simple yet surprisingly complicated—and stressful on components—the MDS system actually is.
So here's my question: Short of a full MDS delete (which would void my warranty), would using a NoLimitz module to disable MDS make it less of a failure point going forward? I assume the MDS lifters would still physically move up and down like normal lifters, but they wouldn't collapse/lock into deactivation mode. Could this potentially 'save' the solenoids (by avoiding constant activation cycles) and relieve stress on the needle bearings in the lifter rollers (thus helping preserve them too)?
As someone who no longer has mds in there 392 my jeep not only gave me a migraine from drone but the lifter noise was a joke! When my dealer tried to fix my mds issue we Also found why I always smelled coolant , leaky head gasket.As mentioned in my other thread, my MDS lifters were shot right from the factory, but they're getting fixed now under warranty. This whole experience has really opened my eyes to how simple yet surprisingly complicated—and stressful on components—the MDS system actually is.
