Livernois tune installed!!
Does HPtuners give you a tune that gets rid of the torque dip (like the livernois tune) and increase power?
Does it do a transmission tune (firmer shifts, etc).
I like the idea that I can tinker with fan temps and such but would like to have a good base tune to start from.
HPTuners doesn’t send or offer tunes they just provide the software and hardware to tune your vehicle. Yes the transmission can be tuned. The engine and transmission can be tuned and flashed separately or both at the same time depending on what changes need to be made to the vehicle.
I see people talk about replacing the thermostat with a 180. This has been tried with every model wrangler for the last 10 years. It does nothing. As mentioned the 392 will still run at 220 with the 203 t-stat. This means is still gets hotter after the t-stat is fully open. So the 180 is going to do the same thing just sooner. And you get the benefit of throwing a t-stat failure code because the Ecm is wanting 203 pretty quick after start up.
only thing that helps with the higher temps is the hptuners change to fan settings. And then your fan runs a lot a lot…. Fought high temps in my JKUR forever and lost…. lots of experience here. That is why it is gone. I can deal with 220, couldn’t deal with 240…
In HPTuners I adjusted the each setting to the lowest temperature for the fans to come on. There is a low, medium and high speed temperature threshold for each setting. For the fans to come on at low speed the lowest it will allow is 196°. After changing the settings I did not notice much if any different in the coolant temperature.
I agree that going to a 180 or 190 t-stat would just make the Jeep warm up quicker and would not provide any benefit. If I could set the fan to come on at say 180 then it would make a difference but looks like it is what is at this point. GM does the same thing with their newer vehicles. The older LS1 and LS2 vehicles did allow for lower fan temperatures. It must be related to emissions.
Did the fans actually turn on?
So with hp would have to find a tuner with dyno to get tuned. I do like being able to mess with stuff. Livernois you are at their mercy for tune updates but you get a good out of the box tune that may not be perfect for your jeep but certainly better than you could do without a dyno.
Just had a thought. If you were on a level road with no wind and did pulls and had accurate data logging you could tune it like that. I wonder if there is software that you give you a "dyno" graph based off data logged speed vs time? The rate of acceleration would equate to horsepower although you would have to account for wind resistance increasing as speed increased and if wind was changing it would make result inconsistent enough to be useless.
Just knocking ideas around. I don't know of an awd dyno close to where I am. Guess I could force rwd with tazer and use regular dyno.
All hell would break loose though if the tazer farted and kicked in 4wd while at high speed on dyno. 🙀
You could always force 2WD mode with the tazer for the Dyno.
LOL someone didn't read the entire post before they replied
No. I typically don’t read every response. Also, with traveling through 5 time zones in as many days, it takes a toll on awareness. 🤣
I just installed my new ECM from HPTuners and was able to flash my tune/changes. I opted to buy another ECM to avoid warranty issues. After installing the new ECM I noticed the P1400 code. I cleared codes multiple times and it didn’t go away. After researching this I realized what the code means and that there is a workaround, we’ll sort of. With HPTuners I can turn of the P1400 code so it won’t show up when you scan the ecm. But the problem with that is 1. If I put my original ECM back in for warranty work it will show the same P1400 code and it hasn’t been modified by HPTuners so I can’t flash it to hide the code. 2. If true the code is stored in a body control module then the dealer will most likely see it whether I have the modified ECM installed or the original. The whole reason I bought the new ECM was to avoid any warranty issues and HPTuners should disclose this information about the P1400 code so that other people like myself know.
To answer your question about the MDS enable and disable speeds it was from 11 mph to 82 mph. Quite a bit higher than the 392 in the cars.
I will keep playing with the tunes etc and read the BCM’s with JSCAN to figure out a solution if one is possible. First I want to see if the code is present in the BCM given I disabled it in the tuning.
I will say it was worth it! I love that the MDS is off now. I also adjusted the electric fans to come on earlier. What temps do your Jeeps run at? Mine is always north of 200. At slow speeds on a trail etc it gets to 220. Having built and owned numerous LS engines that seems really hot.
Did you use the by pass cable from HP? I have the impression if you use this cable it will not triggers the code. I am ready to send my ECM to HP to get it unlock so I can play with it and eliminate the MDS.
If I could do it without messing up powertrain warranty, I'd do it in a heartbeat. I don't want them to blame a failed MDS lifter on a tune.....
Really interested in the livernoise tune but it does seem like a hassle to do. How is the Jeep holding up now?
Will the Livernoise tuner void a factory warranty?
100% it voids the warranty. Jeep can’t have people messing with the electronics / engine and cover the mess if something goes wrong. That’s the risk you take.
Reactions: RJP
Very cool write up. Thanks for sharing your experience ✌ @Idaho392
If something happens caused by the ECM/ECU changes, then the manufacturer has the right, but not the obligation, to avoid the powertrain warranty, etc. You must also be careful to avoid fraud. Finally, using two computers is not necessarily any type of a solution (fraud issues aside) because the mileage on the computers will be different than the mileage on the car.
I know I’m reviving an old thread, but for future reference and internet searches, google TTDyno. It’s older software that does as you had thought about. I used it extensively in the 2013-2015 time period. You have to be able to data log, and it’s helpful to have a wide band O2 sensor as well. It’s as accurate as the info you put in is(garbage in, garbage out).
I learned A LOT about how engines behave from this program(like the effects of heat soak, not optimal a/f ratio & timing/knock retard, on engine output) but, as it is usually said to make 3 pulls on a dynamometer and average them, I would say with this its more like 5 or 6.
For instance, it would show a consistent 25-30hp loss going from a freshly warmed up engine to a heat soaked engine on a 5.7 hemi. Also, it showed why my car at the time didn’t get any faster after installing a water/meth injection kit that claimed a 20+ hp gain. It was because the water/methanol almost eliminated the power loss from heat soak, not that it added 20+hp on top of peak on a freshly warmed up engine, so it did gain 20hp over the heat soaked output, but it was misleading. These things and more!
It was worth every penny to me and I think highly enough of it to revive this old thread.
