Featured
- Thread starter
- #21
It was easy. The only part that was different from their instal video was disconnecting the front "trail" camera and camera washer hose when I removed the grill. The Jeep in the video doesn't have this option. The engine type (Diesel, V6, V8) doesn't; really make any difference as the kit is only dealing with the hood latch and the electronics that are universal in the JL.Was the LasFit Stealth easy to install? I messaged LasFit and asked if it fit in the 392 and they gave me a list of engines that it works on but it didn't include the 392. I'd like the added security without having to carry extra keys. And I'm not going to engineer a work around it it doesn't really install, like many jeepers would do....Thx
It took me less than an hour to install. And about 15 min of that time was taking photos for this thread. No "work arounds" needed. You do need to drill two hole in a plastic plug to get the air line tubes into the cabin from the engine bay trough the firewall. But that is the only physical modification required. Everything else uses the existing OEM parts, so mostly disassembly, adding the kit, then re-assembly. Nothing hard with the correct tool in hand.
Hope that helps answer any concerns.
