Tank2112
- Joined
- Nov 4, 2022
- Messages
- 561
- Reaction score
- 624
- Location
- Florida
- Current Rides
- 2023 Rubicon 392 XR, Custom 2003 LJ with 6.1 Hemi, 2013 Ram 3500
Specs from Northridge 4x4:
This chart, lists out most of the common bolts and nuts you will encounter while working on your Jeep as well as the torque settings required for each of them.
Part
Socket/Wrench Size
Torque:
Wheel Lug Nuts - JK
19mm
95-100 ft. lbs.
Wheel Lug Nuts - JL
22mm
130 ft. lbs.
Front End Components
Track Bar Frame Castellated Bolt
19mm
130 ft. lbs.
Trackbar Axle Mount Bolt
15mm
130 ft. lbs.
Sway Bar Links-Bottom Bolts
T-55 Torx
18mm
70 ft. lbs.
Sway Bar Links-Upper Nuts
17mm
45 ft. lbs.
Bottom Shock Bolts & Nuts
13mm
250 in. lbs.
(21 ft. lbs.)
Top Shock Bolts
17mm
w/small 1/4" wrench on shaft
17 ft. lbs.
Spring Retainer Clip
13mm
16 ft. lbs.
Bumpstop Retainer Cup Bolt
15mm
Hand Tighten
Dana 30 Differential
Cover Bolts: JK - JL
1/2"
30 ft. lbs.
Dana 30 Differential Fill Bolt
3/8" Drive Ratchet
25 ft. lbs.
Steering Stabilizer Axle Bolt & Nut
15mm/18mm
55 ft. lbs.
Stock Castellated Nut
19mm
35 ft. lbs.
Tie Rod End Clamps
13mm
20 ft. lbs.
Front Axle Nut
36mm
100 ft. lbs.
Drag Link Clamps
15mm
36 ft. lbs.
Control Arms
Lower Control Arms Frame
Bolts & Nuts
21mm
130 ft. lbs.
Lower Control Arms Axle
Bolts & Nuts
21mm
85 ft. lbs.
Upper Control Arms Bolts
15mm
55 ft. lbs.
Transfer Case/Transmission
Skid Plate To Frame
3/4”
55 ft. lbs.
Trannsmission Mounts to
Skid Plate
13mm
45 ft. lbs.
Transmission Drain/Fill Bolt
17mm Allen Bit
14-20 ft. lbs.
Transfer Case
Drain & Fill Bolts
10mm
15-25 ft. lbs.
Rear End Components
Track Bar Axle Bolt
T-55
85 ft. lbs.
Track Bar Frame Bolt & Nut
15mm/18mm
85 ft. lbs.
Sway Bar Links Outside Nut
15mm/18mm
40 ft. lbs.
15mm/18mm
74 ft. lbs.
Top Shock Nuts
13mm
23 ft. lbs.
Differential Cover Bolts - JK - D44
1/2"
30 ft. lbs.
Differential Cover Bolts - JL - D44
13mm
25-30 ft. lbs.
Dana 44 Differential Fill Bolt
3/8" Drive Ratchet
25 ft. lbs.
Part
Socket/Wrench Size
Torque:
Wheel Lug Nuts - JK
19mm
95-100 ft. lbs.
Wheel Lug Nuts - JL
22mm
130 ft. lbs.
19mm
130 ft. lbs.
15mm
130 ft. lbs.
T-55 Torx
18mm
70 ft. lbs.
17mm
45 ft. lbs.
13mm
250 in. lbs.
(21 ft. lbs.)
Top Shock Bolts
17mm
17 ft. lbs.
13mm
16 ft. lbs.
15mm
Hand Tighten
1/2"
30 ft. lbs.
3/8" Drive Ratchet
25 ft. lbs.
15mm/18mm
55 ft. lbs.
19mm
35 ft. lbs.
Tie Rod End Clamps
13mm
20 ft. lbs.
Front Axle Nut
36mm
100 ft. lbs.
Drag Link Clamps
15mm
36 ft. lbs.
Control Arms
Bolts & Nuts
21mm
130 ft. lbs.
Bolts & Nuts
21mm
85 ft. lbs.
15mm
55 ft. lbs.
Skid Plate To Frame
3/4”
55 ft. lbs.
Skid Plate
13mm
45 ft. lbs.
17mm Allen Bit
14-20 ft. lbs.
Transfer Case
Drain & Fill Bolts
10mm
15-25 ft. lbs.
Rear End Components
Track Bar Axle Bolt
T-55
85 ft. lbs.
15mm/18mm
85 ft. lbs.
15mm/18mm
40 ft. lbs.
15mm/18mm
74 ft. lbs.
Top Shock Nuts
13mm
23 ft. lbs.
1/2"
30 ft. lbs.
13mm
25-30 ft. lbs.
3/8" Drive Ratchet
25 ft. lbs.
