Is torn front axel boot covered under drivetrain warranty?
Cali392JL
Los Altos, CA
2022 White JL 392XR
I have a 2022 Rubicon XR, mildly modified. The passenger front axle drivetrain boot has a crack and is leaking grease. It looks like the factory warranty covers axles for five years, 60,000 miles. I'd rather get this done for free at the dealer rather than do it myself. Do you think my 37 inch tires or any of the other modification shown in my signature would cause the dealer to void coverage?
Also, would I need to have my taser and/or no limits removed when I take it in?
Hi,
I'd call up your dealership and ask before you bring it down there, as it's a moving part, I would doubt they'd cover it but worth a shot.
Regards,
Jim
My friend's axle boot was covered by one dealer only after the first dealer said no because he did something he should never do in a Jeep Wrangler: take it off-road (gasp!)
A axle boot tears and leaks out the oil exposing the joint to the elements. A 37" tire won't do that, but off roading could. Apparently, these vehicles are designed for the mall, not the trail. Who knew.
Yes, unmarry the Tazer and remove it. Don't make it easy on them to reject.
Thank you guys for the advice. I called the dealer. They said it would likely be covered unless I had done anything to the vehicle which might void their coverage. I unmarried the taser left in the no limits and took it down there. I just got a note back from them saying that they would cover the axle boot under warranty. I was happy about that as the vehicle has lots of scratches on the under body armor from a few trips that we've taken. I don't think they had anything to do with the axle boot and I'm really happy with the dealer for covering it.
I've had my dealer replace 3 already 🤭 They know its abused and remind me I need an aftermarket front drive shaft each time. Mine tears when I am at extreme flex and give it some skinny pedal.
3" Clayton Lift on 38's.
Have you replaced your front driveshaft's? If so, what did you go with?
I have not yet, but its next on my list. I will be regearing to 5:13 gears and upgraded diff covers first since I daily drive my 392. Jumping from 35's to 38's, I lost a lot of torque and that "throws me back into my seat feeling" on the stock 3.73 gears.
Followed by an Adams/ Tom Woods front drive shaft replacement (Will be ordering through here with "jeepguru", he gets us great deals on parts through his company.
