chrisazm
- Thread starter
- #21
Here is a macro close up…hope my 2 cents gives a little relief…
So my original post was about the hood specifically because it is steel and the hinges are aluminum. Maybe they have done enough on newer vehicles or maybe not.
The hood area:
Hinge- aluminum
Bolt- steel
Hood- steel
Corrosion when water contacts gets between hood and hinge or between bolt and hinge
Tailgate: same as hood
Door hinge area:
Hinge- aluminum
Hinge pin- steel
Bolt- steel
Door panel- aluminum
Backing plate the bolts thread into- steel
Bottom of door panel has a steel plate inside as well at the curve.
Possible corrosion when water contacts between bolt and hinge, hinge pin and hinge, or inside door panel and steel plate. My gut tells me that most corrosion occurs when water gets underneath the hinge and inside the door panel. This causes corrosion between the backing plate and the door panel which it why it bubbles from the inside. I don’t know if they have done anything to prevent this. Isolating the hinges may prevent the hinge from bubbling. The gap looks like it will allow even more water inside the door panel. Maybe the newer models are ok but the older ones definitely aren’t. If you want to cross your fingers go ahead but if you want to fix it yourself I am offering a solution. I am painting all surfaces and using paint and RTV to prevent water from entering the areas where the metals contact each other. No bare metal and no water. Double protection!
