This is correct.I did a lot of homework on this issue.
Apparently Jeep uses unprimed aluminum hinges and bolts them to unprimed aluminum doors. They are fastened with steel bolts which leads to galvanic corrosion.
Afaik there isn’t one. Most let the dealers fix it; some say it hasn’t returned in X years of ownership, whereas some say it returns 6 months later.Is there consensus on a proper fix?
You would have to unbolt your hinges and risk breaking that paint seal as well as damaging the bolts as they are installed prior to painting at the factory. If you’re changing out hinges then yes, this makes sense but just to damage the hinges that are there put this in my opinion might make Pandora’s box openClosest correlation I've seen is sailboats, where steel bolts are screwed into an aluminum mast. Sailors are using this product to protect against corrosion and seem pleased with the result.
Ultra Tef-Gel
Wonder if it would help here?
We’ll they probably figure not everyone will bring it to be repaired. And it’s not like it’s hindering salesApparently the bean counters rule at Stellantis. They would rather pay millions in warranty claims than introduce a permanent solution.
Was it driven in the snow with salt on the ground? Hoping I can avoid it here in FL. I know it may be caused by dissimilar metal but the salt sure helps it.Our 2018 MojitoJeep ended up having all 4 doors and the hood repainted in the last year because of it.
It's not daily driven, but we are here in Chicago and have had it out in the winters with salt.Was it driven in the snow with salt on the ground? Hoping I can avoid it here in FL. I know it may be caused by dissimilar metal but the salt sure helps it.
When it happened on my 2015 JK, I brought it in just before the factory 3yr/36K warranty expired and it was fixed perfectly. Had the Jeep another 5+yrs and there were zero issues.Afaik there isn’t one. Most let the dealers fix it; some say it hasn’t returned in X years of ownership, whereas some say it returns 6 months later.
So... I'm going to weigh in here with a few things...
Firstly, I have seen the galvanic corrosion due to the dissimilar metals theory, but given where a lot of these paint bubbles first present themselve (on the door), I think the whole theory that "the steel bolt through the hinge and door is causing galvanic corrosion" is less likely to be true than another theory that I have heard floated, and that is...
Poultice corrosion.
The theory goes... Due to Jeep not (or was not) properly prepping the aluminum for paint and in part due to the unprimed contact point between the hinge and the door panel and poor paintwork around where the hinge and the door panel meet, the paint at the contact point is very thin and easily disrupted or compromised, allowing for a breach point in the paint to be easily created through which water can enter (if a breach point doesn't already exist from poor paintwork at the factory - I have seen some really terrible paint coverage around the hinges on brand new Jeeps sitting on dealer lots). Due to aluminum's nature, it forms an oxide coating when exposed to the elements, but paint arrests the formation of this oxide coating... until the paint is disturbed or compromised. Water gets in through this breach point and then it's all downhill from there.
I am going to copy and paste and explanation of this process from a boating website, because it's written better than I could write it, and I will supply the source link...
"The paint works well until it is breached, and water enters the rift. This breach could be caused by a fastener, an antenna base, a navigation light, a hinge, a lockset, a nick, or a scratch—and it could be microscopic. Initially the wound is self-healing: The oxide coating forms, but instead of protecting the aluminum, it lifts the edge of the paint and allows water to migrate farther under the coating. At that point, the chemical equation changes, as moisture and aluminum, in the absence of air, are the ideal incubators for a phenomenon known as poultice corrosion. When this happens, the aluminum pits and produces copious amounts of aluminum oxide powder or, when wet, aluminum hydroxide, which looks a bit like freezer-burned vanilla ice cream. The formation of the oxide or hydroxide lifts the paint, causing the familiar and unsightly blister, which eventually falls off, exposing raw, pitted aluminum. The process doesn’t stop there, as it begins anew at the interface between the paint and exposed aluminum. While it progresses slowly, once it begins it’s difficult if not impossible to arrest without removing the blistered paint, cleaning, priming, and repainting the surface.
I think this is much more likely to be the culprit, as if it were the bolts, then we would see the corrosion issue start at the bolt and work its way out. The overwhelming majority of paint bubbling issues I have seen are around the hinges, but they don't start at the hinge and work their way outward. They start on the door around the point where the hinge and the door meet, and the paint is thin.
Keeping Paint on Aluminum - Professional BoatBuilder: An IBEX Technical Journal
Professional BoatBuilder Technical Editor Steve D'Antonio describes how to prevent paint from corroding on aluminum surfaces.www.proboat.com
Secondly, I want to remind everyone that the internet is an echo chamber. While it seems like there are a lot of reports of paint bubbling when you get on forums and Facebook groups (and frankly TOO many reports, if we are being honest), the number of reports are only a small fraction of the total Jeeps produced each year... Again, this issue has been going on too long and has affected too many people and it absolutely should be addressed by Jeep, however... I think if we looked at total production numbers of JKs and JLs produced versus total number of JKs and JLs affected by this issue, we'd see it is a rather small portion of the whole. I had a 2015 JK (since sold), and I'm in Colorado and it was driven a lot in the winter months between 2016 and 2021, and I never had a paint issue around the hinges. My 2021 JL was has no signs of the issue either. It almost feels a bit like Russian Roulette with better odds.
That being said, I sincerely hope Jeep has done something to address whatever the catalyst is for the corrosion because I certainly do not want my soon-to-be-built 392 experiencing the issue.
Agree wholeheartedly.
I am in New England. When I found out about this issue I looked at every JL I could find in a parking lot. I'd say my results are 50/50. I saw as bad as bubbling all over the bottom of the doors, away from the hinges to nothing at all. Obviously I can't tell you mileage or any history of the Jeeps I saw but do know I saw some without issue and some that probably would make your eyes water.
OMG that lady at 3:19 should never be touching a car...Jeep Wrangler painting process (video link set to start at 1:42)
That's cool and all but you know if BMW, Porsche, etc were building this 392 it would cost upwards of $140k+. I'll stick with Jeep, thanks.I really wish Jeep would use the process that BMW, Porsche, and other German manufacturers use for painting vehicles...
