Did yours ever turn red?Same here. No indication of miles to go on tank. FWIW
Yes turned red and stayed red.Did yours ever turn red?
I guess I still had some gas then...lolYes turned red and stayed red.
I like the Titan, but I would not want it on the stock carrier with all of the weight on the tailgate. So, if I have to change the carrier anyway, I'd probably just go with the AEV system.What do you think about Titan's 12 gallon option?
TITAN Trail Trekker II™ Tank for Jeep JL
Link: View attachment 35827
I asked them about the Titan and running on 38-40" and they said it would fit but they couldn't guarantee it would be OK due to weight. The teraflex carrier should hold more than enough weight so I'm gonna give it a shot...I like the Titan, but I would not want it on the stock carrier with all of the weight on the tailgate. So, if I have to change the carrier anyway, I'd probably just go with the AEV system.
or... I'm considering the NV Scout rear winch capable bumper/carrier, in which case the Titan would be a no-brainer. Still perseverating on it.
https://nextventuremotorsports.com/...earwinchbumper-carrier?variant=39448823464129
If the AEV setup still had the integrated water tanks.... I'd lean towards that, but they removed them I think for the JL.
Another thing to note is both the Titan and the AEV setup with the fuel tank supports up to a 37 inch tire, if you want to run larger meats, you're out of luck for a spare mounted tank.
Report back when you do, I'd be interested in hearing your take on it.....I asked them about the Titan and running on 38-40" and they said it would fit but they couldn't guarantee it would be OK due to weight. The teraflex carrier should hold more than enough weight so I'm gonna give it a shot...
