first oil change
great one 99
New Hampshire
ford raptor
did my first oil change 700 miles ,its been 6 months , ine had that normal hemi noises at idle , after the oil change totally quiet ,anyone else notice this after the first oil change?
I changed mine at 500 miles but never heard the tick. Was the oil level proper prior to you change?
Mine has always tic tic tic for about 30 -40 seconds after a cold start . Pennzoil SRT
i dont know i never checked the oil levels before .i had the tic for 5 seconds at start up ,then just what i though weas normal hemi noise, after oil change noticbly quiet. maybe it was low .
If Jeep was still warm after oil change the tic would not be there
true , but it was even quiet at idle ,which it uslly sounds a bit like a type writer
could be the dastardly expired oil that was all the rage here a few weeks ago 🤣
really just could have been low or maybe that particular filter was not flowing as well vs the new one.
I got the Hemi valve lifter tick once after not waiting long enough after a cold start (opened the hood after remote starting it)
I do get the Hemi exhaust chirp/tick though and it varies with how hot it is out and how hot the exhaust/motor is.
i did usr the white srt oil filter ,is slightly oversized
Do recall what filter was on it? we have 3 filters that 'fit' a smaller one-339, larger one-899 and the white SRT one-041
from my understanding the 899 and 041 are pretty much the same volume but the white one has a different design optimized for higher flow.
w
i will look in a few i still have the filter,it was like half the size of the white one
Well known issue, fluids not filled correctly from the factory.
I thought that was just the diffs , oil is part of that that
Mine was close but not full. I've seen low levels noted on diffs, TC's, transmissions, etc. I would check everything.
I concur it’s an exhaust chirp
so after sitting overnight ,no tic on startup ,or idle at all .oil filter has a slight drip ,retighten with filter wrench.its hard to tighten by hand as its so big ,unless u have, seinfeld man hands
