Fender mounted ARB Twin?
Hi Winston. What year is yours? The 2024 has electric seats. And at just 5’10”, they don’t go down far enough even for me. I wouldn’t want seat jackets on mine for sure.
Mine's a 24. I only have the jackers on the passenger side, not driver side. I wouldn't want them on my seat either, and I'm 5'7". I only did it for the compressor. The wife doesn't seem to notice a difference haha.
Under the passenger seat, with Seat jacker is perfect. I kick my AC on high and turn it to floor and it keeps it nice and cool.
It takes 5 minutes to air up 40s from 10 to 29 so tell your wife to get out and get you a beer during that time.
My wife likes to stay seated when the compressor is going. I wonder what that's about...
Could you share any photos - and anything you'd change if you were to do it again? Agree on not putting anything outside that I can keep dry/inside.
The NoLimitZ works perfectly all by itself. No Tazer needed.
Found this thread off a search, but wanted to ask and confirm....
I currently run the tazer, can I unmarry my tazer, and install the No Limitz without the Tazer?
Also I'm not seeing Force RWD as a feature on the No Limitz, is it available or would i have to run the tazer as well?
Thanks!
Thanks!
Would also need a Tazer to do what you want.
Thanks!
You can run either device or both. And there are no features common between the two devices. ForceRWD requires Tazer. I’m running both devices and they work well together.
Thanks!
You can run either unit by itself or at the same time, they're separate units and are not dependent on each other. Force RWD is Tazer only.
finally got my single compressor in that I rescued from my poor Xterra, it was a major PIA but all in all it went well.
recommend replacing the tailgate latch bolts with longer ones as mine where extremely short and needed the extra threads
finally got the compressor in, it was a major PIA but all in all it went well.
Nice work. Consider moving the air intake to inside the cabin for clean filtered air supply.. There is a factory hole in the body just above that's is perfect for routing the fresh air supply Also, cap the air chuck.
Did you make the reinforcement plate inside the fuel filler door?
I did not, its from next venture. comes with the QD fitting also
If I had known the twin arb would fit in that spot I would’ve put mine there instead of in back of the rear seat . For noise reasons in the cabin. Good job
thank you but its just a single, I should be more clear in my original post
Where did you pull the power from? That little 12v supply in the back?
I basically mirrored the ARB harness, main hot from bat, to a relay ground off of the chassis right by the 12v socket, switch hot off of the 12v so it only able to be switched on when the vehicle is in ign/running
