Differential Covers
How do you like the 2" spacer lift? Any issues with it? It doesn't take much to bottom out the front suspension and when that happens, it's harsh. Seems like 2 inches would be a big help.
It has been good so far. I got the AEV lift. Easy install and gave me a little more room as I put some 35’s on it. I would highly recommend for the money.
Where did you guys find to the best source for the ARB covers?
Are they listed as a specific item for the 392?
Thanks!
I got mine from Quadratec. They weren’t specific to the 392, just need to make sure you get the ones for the Rubicon axels. I took mine off my Gladiator when I traded it in.
Thanks!
I got mine from Quick Performance. They were on Amazon but I ordered direct from them, no CA tax and free shipping. They had the black in stock and shipped same day. M210 is the front axle, M220 for the rear. ARB part #'s are 0750011-front and 0750012. Add a B at the end if you want black.
1/2” thick ring and 3/8” cover, quality bolts. Clear painted a few coats. Best part is no logo, raw steel beauty and perfect welding.
Did you re-use the factory gaskets and bolts?
I reused the factory gaskets. The factory bolts are not long enough for the beef. I bought the RuffStuff bolts which are high quality.
Thank you. I really like those and the fact that I wouldn't be be advertising for anyone seems very appealing.
Exactly! I’ve done a lot comparisons and all the other JL diff covers on the market just don’t offer the same beef. And I like raw steel look too. I won’t be installing any diff skid plates considering how beefy the RuffStuff ones.
I’ll change the diff fluids after another 30K miles if not sooner and buy new gaskets. Good time to inspect the gears and pinion. I don’t see the point of having a drain hole.
Don't have direct experience with this but my conversation with ARB was that if you have the Steer Smarts track bar installed it will interfere with the ARB cover.
Since Jeep in its infinite wisdom decided to remove the drain plugs on the front and rear differentials starting with the 2022 model year, thereby requiring the entire cover to be removed to change the fluid, I’m thinking of swapping out the covers for ease of future use. Of the various options, I’m leaning towards the ARB Covers. There is some conflicting feedback in the reviews for the front cover that it can be challenging to install, but rear is all positive. Wondering if anyone has any real-world experience with these covers and can offer any feedback? Or, alternatively, any recommendations on any other brands? Many thanks!
Hi, Can you tell me the amount of oil that you used in the front and back. I just installed my covers and using 1.4 quarts in the front and 1.6 in the rear is putting me about the marks in the dipstick that I transfers from the fill hole of the stock covers. Thank you in advance for any help.
I installed ARB on my JKUR. Bought them again for the JL 392. Haven’t installed yet. Waiting to hit the factory recommended change interval.
Sorry for the delayed reply, just now seeing your post. I didn’t keep track of the specific volume that closely, so I’m not sure on exact amount of fluid I used. It’s less about volume with ARB covers vs OEM amount than it is about height of fluid pool up to the gears at the level equivalent to what it would be with OEM covers to the bottom of the fill hole. I found marking the dipsticks wasn’t especially helpful as they’re still difficult to read accurately. My solution was to cut a couple of the plastic tubes that go on the hand pump I used to pump fluid from the gear oil bottles into the diffs at the length equivalent to where the bottom of the OEM fill hole would be. I then slightly overfill the diff, insert the pump with the shortened tube down into the ARB fill hole, and pump out the slight excess. Once it starts sucking air, your fluid is at the correct level. I found this approach much easier, faster, and more accurate. Hope this helps.
Thank you, will try your subjection , I also found reading the dipstick very difficult.
I am late to the party but I am 100% for the ARB for anyone else that comes across the thread. We installed a Yukon locker just before running Rubicon in my JK- after a shake down run it was making a whirring noise. Turns out the carrier bolts were not installed properly at Yukon and they'd come lose in the cover. The ARB magnetic dipstick had held a huge gob-stopper sized ball of metal shavings away from everything. Somehow nothing was damaged- replaced the locker and ran Rubicon. That was probably 9 years ago. I've also bashed it plenty of times.
As a result I am paranoid about diff fluid. I've checked it numerous times and found it easy. (I've had diff fluid in my ponytail more times that I can count.) Changing diff fluid doesn't happen all that much so the no-drain issue isn't an issue for me- I take it off, fully inspect and replace the gasket. Only cover I'd ever buy.
Plus the ARB matches the red MY24 seats :)
Mine too- in the JK at least. (Bar Tact seat covers) Lots of her bits were PC'd red. Her name was Elvira.
Lots of lift and tacky red lipstick. :cool:
