Anyone with a 2021 or 2022 still using the original battery ?
Still on the original battery in my '21. The battery manufacturer is East Penn / Deka. I have tested it regularly, both with a solid state tester and a load tester. Both indicate the battery is at 90%+ of original capacity.
I usually put a maintainer on the battery if it will be more than a few days between drives.
LF
LF
Cooler weather helps batteries last a bit longer .not worth the chance in Arizona
