- Jul 3, 2025
- 634
- 1,011
- Current Rides
- 2025 Rubicon 392, 2008 Hummer H2, 2018 JLUR Retired, 2015 JK Sahara 2dr retired,
Station378, I think your looking into your crystal ball and possibly seeing the not to distant future!
IMHO, Currently we are enjoying a brief pause in the automotive climate, so enjoy it and take advantage of it if you can. It won't last long and the dark side will return and when that happens say goodby to anything that has a V8 and probably consumer diesels as well. All we will be left with is electric crap that catches on fire, 4 cylinder sewing machine engines with big turbos that blow up with under 80k.
In all honesty I believe the fate of the 392 and high performance vehicles are directly in some part related to the political makeup of the country. When politicians (via epa and other restrictions) place roadblock against auto manufactures it negatively affects their bottom line. They then come up with and force the implementation of so-called fuel saving and environment devices that kill the reliability and longevity of vehicles and there you have it.
Think about it, engineered obsolesce, what is the weak point of the 392? MDS and cam/lifter oiling issues. On top of that these so called fuel saving boondoggles to really save any REAL fuel and just cause problems.
These are legacy engines with epa crap shoehorned into them, the original 392's version were bullet proof and lasted for decades. If it wasn't for MDS these engines will easily go 200k miles much like the GM counterpart LS engines. Again, governments fingers in the mix. I have been around long enough to tell you the same crap happened in the seventies and you saw what happened then.
Currently we are enjoying a brief pause so enjoy it and take advantage of it if you can. It won't last long and the dark side will return and when that happens say goodby to anything that has a V8 and probably consumer diesels as well.
All we will be left with is electric crap that catches on fire, 4 cylinder sewing machine engines with big turbos that blow up with under 80k and everything will be regulated to the 9th degree.
Finally, another attributing factor is that Gen Zr's could care less about large displacement performance vehicles, they don't wish to pay for performance, the fuel or wrench on them either. Automotive manufactures know this and will continue to cater to them as time goes on.
Cheers all! Enjoy this dying breed and keep the smile on your face every time you start it on romp on the throttle. All of us here on the 392 forum are so fortunate to be able to enjoy these beasts before they go the way of the dodo!
