For those that don’t know, most (if not all) +3.5” lifts require a new front driveshaft and an extended-travel shock may require new front and rear driveshaft and/or limiting straps, regardless the lift height.
Based on the pic, I’m assuming this is a front driveshaft and you were running a shock that was specked for a bigger lift?
If the answer is ‘yes’… don’t forget to check your clearance, at full droop, because the added down travel may exceed the limits of your other suspension components. Bent or slipped driveshafts, bent end links, or individual springs popping out from their perches are the most common things I’ve seen on the trail.
Heck, even when taking the necessary precautions… stuff happens on the trail that can’t be checked in the shop and sometimes stuff just breaks.
In my own case, I run King coilovers and I’ve bent a front end link over my tie rod while going over something I should have gone around, ruined a new set of AAL rear inner fender liners on my rear Antirock that I thought would clear, and snapped my front locker line going off a drop no one else would do... It’s just part of the game
