Differential Covers
Jgc650i
🏆 392 of the Month
North Carolina
2022 Jeep 392 XR, 2022 Ram 1500 Limited, 2024 Audi SQ8
Since Jeep in its infinite wisdom decided to remove the drain plugs on the front and rear differentials starting with the 2022 model year, thereby requiring the entire cover to be removed to change the fluid, I’m thinking of swapping out the covers for ease of future use. Of the various options, I’m leaning towards the ARB Covers. There is some conflicting feedback in the reviews for the front cover that it can be challenging to install, but rear is all positive. Wondering if anyone has any real-world experience with these covers and can offer any feedback? Or, alternatively, any recommendations on any other brands? Many thanks!
1/2” thick ring and 3/8” cover, quality bolts. Clear painted a few coats. Best part is no logo, raw steel beauty and perfect welding.
I looked at those too and thought they’d be a great option. But still no drain plug from the looks of it.
Drain plug is a no to me. It doesn’t drain all the fluid due to the position. It’s also an easy failure point. You may have a hard time taking it off if damaged.
And I like to inspect the gears and pinion by taking the cover off. Putting a new gasket ring seal is super easy too.
I hear you and don’t disagree. I’m probably a bit overly fanatical and cautious when it comes to the differential oil. I have a tendency to change it out much more frequently than required. I like the convenience of not having to pull the cover off completely. I do generally every other time and fully flush out with cleaner, etc. I like the strong dual magnet setup in the ARB so if there’s anything excessive it’s definitely a sign to pull the cover for sure, just don’t want to have to every time.
A vacuum extractor makes quick work of draining anything like that. I hardly ever remove the drain plugs on small engines, gearboxes and such. Suck out the old, add new... no risk of stripping a plug or crawling under to find out you have the wrong tool...
The only thing I found with the ARB front cover is that if you have a Teraflex Falcon steering stabilizer mounted in the factory spot on the axle, there is interference at full lock. Moved it to the tie rod and no issue (edit: the other end is moved to the track bar bolt, to be clear).
Covers are nice, easy to install, and the factory gasket is reusable.
Understood. Without taking off the cover, a transfer pump or gear oil extractor will work fine as long as you measure the amount out.
Will the same replacement gasket fit on both the Dana M210 and M220 diffs?
Any recommendations for an extractor that you like?
I have the ARB on mine and they work great. No problem installing the front one.
Is your Jeep stock how close is the tie Rod to the diff cover at full lock turn either direction thanks.
Could you simply drill a drain hole in your factory cover, use a threader, buy a plug?
I did that with my Dynatrac ProRock 60 axles on my TJ.
Or does Mopar offer Jeep 22' year model diff covers? ....if they have a drain plug?
Yes mine is essentially stock. I do have a 2 inch spacer lift. Here is a pic of the space I’m front of the cover. View attachment 16835
How do you like the 2" spacer lift? Any issues with it? It doesn't take much to bottom out the front suspension and when that happens, it's harsh. Seems like 2 inches would be a big help.
