Question - I was not aware there could be additional cooling benefits. Am I missing it in the pictures? 24 grill has wider open surface area but shorter height area? Is the thought the taller height on pre-24 grill is blocked by winch? Or maybe the scale is more understandable in person?
My 2023 392 in Sting Grey came with the Mopar Performance Grill option. Is the 2024 Mopar Performance Grill different than the 2023? Would you keep the 23 performance grill or opt for the 2024 painted version?
I love that color!!! Now you gotta go all in and match that Warn logo. @Underground Graphics has a Warn winch decal kit that matches the 392. That is an awesome Jeep!I did my 2024 Custom Paint myself. I do like what you did looks real good. Check out mine.
I LOVE the new grille.Got mine last week
Look goodGot mine last week
Interesting comparison of the space behind the winch with the regular JL grill and the new 24 grill. These are both on my 21 392
They painted mine matte black with the slot trim red.That's really helpful to see comparisons like that. I have my 2024 grill waiting to go on - just got it back from the detail shop getting PPF installed. My 2023 grille is very close to my winch, like less than 1/2" inch. I'm going to have to remove my winch to get the 2023 grille off.
But - I decided I don't like the unpainted trim portion around the slots and the headlights. I talked to Brian at Distinction Applied and ordered the trim in matte black. Once I get it, I'll return the unpainted one for the core charge refund.
It's certainly no fault of Distinction Applied, but for those ordering a 2024 grille, I'd give some serious consideration to getting the trim painted for the extra $100. The color it comes isn't standard on any Wrangler trim level. Rubicon Grey would be the OEM finish.
Just something to think about.
Great writeup...curious though, I am able to get the Camera assembly off my 22 Grille, but I am having a challenge getting the sprayer off. I've disconnect the water line, but the actual sprayer does not want to budge and I can't remove it. Do you have any suggestions to remove the sprayer assembly? Thanks in advance.Just wanted to post a thread on installing the new 2024 grille on an earlier 392. I ordered my grille from distinction applied back on Oct 16th for $640 with free shipping painted to match my Firecracker Red (PRC) 2022 392. I received it December 8th, and the paint job looked great! It was a perfect match to my factory paint. After that I took it over to get paint protection film (PPF) applied. They used gloss for the red and matte for the painted grey that was $235. When I was dropping it off they noticed a crack on the driver's side top of the new grille plastic. Not sure how it happened, but I was able to stop drill it and repair it. Not exactly what I wanted to see on a brand new part, but at least it's hidden under the foam pad so no worries.
The install is easy, first I removed the pax side and driver side foam seals which are attached with 2 Christmas tree connectors each. Then I removed the front hood to grille seal gasket 12 more push connectors. Then I pried up the 6 push pins on-top of the grille, then removed the grille by pulling out on the bottom which is attached with 6 clips. I detached the front camera connector and the camera sprayer hose and the grille was free.
Now it was time to move over the front camera and sprayer. The sprayer was the easy part, secured with two small side clips. The camera on the other hand was a head scratcher. The grille came with a new camera back bracket which fit the camera perfectly. But then when it came time to run the camera wire I couldn't figure out where it was supposed to go. I'm guessing on the 2024 jeeps the camera must connect above the radiator next to the hood latch rather than below the driver side headlight like on my 2022. So I had to resort to zip ties
and run the wire over the top of the driver side headlight. If someone with a 2024 wants to post a pic showing where the front camera connects to the grill that would be very helpful.
So after mounting the new grille and moving over the two foam pads and front seal I called it good.
A few final thoughts... Love it or hate it, the new grille is defiantly shorter and should make adding a Warn winch easier. I'm not sure if it actually allows for more cooling. For now I'm going to leave it on for a while and see how it fits the Jeep. It only took about half an hour to swap. That's one of the unique things about owning a Jeep, it's like Lego you can just change it if you want. Try doing that with a modern unibody vehicle.
I've actually always wanted to mount a grille some headlights and some tires cut in half in the back of the garage to make it look like a Jeep coming through the wall, so now I have a spare grille to do that with. I hope this is helpful to someone thinking about adding a 2024 grille.
I think there is a small locking tab on the bottom of the sprayer nozzle part. I kinda remember it being a pain in the a$$ to remove it. I think I used a small pick under the tab to wedge it up. Here is a pic of the grill with it removed so you can see where the tab is. I don't have a pic of the sprayer by itself but the good news is it's only $10.80 Mopar (68370210AA).Great writeup...curious though, I am able to get the Camera assembly off my 22 Grille, but I am having a challenge getting the sprayer off. I've disconnect the water line, but the actual sprayer does not want to budge and I can't remove it. Do you have any suggestions to remove the sprayer assembly? Thanks in advance.
I haven't noticed any impact on engine temps. Based on some measurements I think you actually get about 25% more air flow with the new design.For those with the warmer weather, any difference for cooling? Even if no more cooling, just wanting to make sure we don't notice an increase in temps.
Thank you brother...I appreciate your feedback...may look to do this over the weekend and it's good to know that it is a replaceable item.I think there is a small locking tab on the bottom of the sprayer nozzle part. I kinda remember it being a pain in the a$$ to remove it. I think I used a small pick under the tab to wedge it up. Here is a pic of the grill with it removed so you can see where the tab is. I don't have a pic of the sprayer by itself but the good news is it's only $10.80 Mopar (68370210AA).
www.distinctionapplied.com
