- Sep 20, 2021
- 2,253
- 2,495
- Current Rides
- 2021 Rubicon 392 2006 Jeep Wrangler Unlimited Rubicon
Featured
- #1
Just purchased the AAL Cargo Shelf and I'm very happy with it. I thought some might find it helpful to post a full review. The shelf is very sturdy, almost overbuilt. It came packed very well. Parts:
Aluminum: (these are all black in mine but other colors are available)
2 x Shelf Halves
2 x Roll bar brackets (driver and passenger side specific)
2 x Shelf Brackets (driver and passenger side specific)
Steel: (these are all red in mine but other colors are available)
2 x Middle Supports
2 x Outside Supports
2 x Edge Guards
Assembly is straightforward with lots of fasteners.
It attaches to the roll bar after small trim pieces are removed.
The height is adjustable. Right now I have it in the second lowest position and that provides 19 inches of room underneath.
There are 4 adjustment holes to go higher as long as you are ok fastening the shelf brackets to the roll bar brackets with 2 bolts per side rather than 4. Each hole moves it just over 3/4 of an inch.
I will probably use it without the front and rear edge guards on until I need them.
I plan to install an LED light strip and switch for underneath the shelf.
2 x Shelf Halves
2 x Middle Supports
2 x Edge Guards
