Featured
- #1
There have been a few threads on here about 392s getting stolen, so that’s had me thinking about security
. One of the biggest vulnerabilities of the Jeep JL design is that there is no hood lock from the factory. Not locking the hood makes stealing or tampering with the 392 much easier. But it’s a Jeep, and I like that stays true to its 79 year history.
There are some options to address this vulnerability:
I spent my own money so this is my take on it. Shipping was quick.
It uses a pneumatic slide to lock the hood safety latch hook. There is a little pump module that you mount in the cab that controls the pneumatic hood lock. It connects to the Jeep’s OBD port (on board diagnostic port) using an OBD pass-thru to provide electrical power only, so if your using a Tazer on the OBD it should work normally, but I don’t have a Tazer myself to test this out. It also connects to the CAN bus (controller area network bus) where it gets the status of your door locks and the key fob inputs. It will then lock the hood automatically when you press the lock button on your key fob, or the button on your remote keyless entry door handle. Then when you open your door either with the key fob or keyless entry door handle it unlocks the hood, so you can open the hood and show off that big beautiful V8 hemi
It took me about 1 hour to install it. The kit is well made, and is IP66 rated (ingress protection – no dust, strong jets of water) they have an easy to follow YouTube video. It also has a dead battery mode to open the hood in case you need a jump start. I can’t speak to the long term reliability but everything looks automotive grade (probably repurposed from some other vehicle... exactly what FCA/Jeep would do
) so I’m hopeful it will last.
So after I installed this little hood lock dohicky I re-evaluated my security setup. Now that I can lock the hood, if I pull the starter fuse it would very difficult to drive it away under its own power
. So I glued a little plastic game piece (from the board game Sorry… seemed appropriate) to the top of the 40A fuse to make it easy to identify and remove. Now I’ll be the first to admit that this is not a long term solution, but for the occasional vehicle incapacitation it’ll do. I'm not recommending others do this, just sharing my current SOP. I very rarely need this increased level of security. I may explore adding Ravelco or other option down the road.
Anyhow that’s my review of the LASFIT Stealth along with Starter Incapacitation Technology (S.I.T.) theft prevention device. I hope it’s useful.
- After market locking hood latches like
this one pictured on the right from @CBH . The downside is you have an extra set of keys
to keep track of. - Grill Installed lock from Mopar or Bolt. But if you have the front mounted Jeep TrailCam option then these won’t fit so that wasn't an option
. - LASFIT Stealth; no keys, it fits with my existing grill mounted TrailCam, and there is no cutting or grinding so you can always go back to stock. Winner winner chicken dinner!
