CAMEL2R
Army Veteran
Featured
- #161
Classy!BC Forged 17x9, -12
BFG KO2 37x12.5
20lb lighter per corner than the OEM setup.
BFG KO2 37x12.5
Not enough tire side wall flex for me while aired down with 20 inch wheelsAnyone tried GC SRT or Trackhawk wheels 20x10 & 37x12.5R20? Could be too heavy though.
Lighter is goodClassy!
Very true. One of the hallmarks of a Mall Crawler is too much wheel and not enough tire.Not enough tire side wall flex for me while aired down with 20 inch wheels
Or these bronze replicas @ 31 lbs. per corner plus tireView attachment 42547.
Go big BearOr these bronze replicas @ 31 lbs. per corner plus tireView attachment 42547.
Good off the lineVery true. One of the hallmarks of a Mall Crawler is too much wheel and not enough tire.
Perfect , looks great. Thanks
Definitely a fan of the 17x9 -38 wheel. I assume that's the wheel size you are running ? Question on Beadlock , how often to you check bolts ? Never ran them before, love the KG 1 you run. ThanksVery true. One of the hallmarks of a Mall Crawler is too much wheel and not enough tire.
I check them after each off-road trip. If I'm not doing any trails, I check them every couple months.Definitely a fan of the 17x9 -38 wheel. I assume that's the wheel size you are running ? Question on Beadlock , how often to you check bolts ? Never ran them before, love the KG 1 you run. Thanks
Agreed, this would be more of a "road" setting.Not enough tire side wall flex for me while aired down with 20 inch wheels
Always!Lighter is good
Agreed. Mine is certainly not a mall crawler as I do a fair amount of wheeling...I'll do everything but the John Bull trail. Since mine is a daily driver, road manners are first priority. When I retire, it will transform into a true wheeler. Then I'll add a Trackhawk for road duties.Very true. One of the hallmarks of a Mall Crawler is too much wheel and not enough tire.
To clarify, I do not use Mall Crawler as a derogatory label. It's there vehicle, and if 27" wheels with rubber band tires are what they like, good for them.Agreed. Mine is certainly not a mall crawler as I do a fair amount of wheeling...I'll do everything but the John Bull trail. Since mine is a daily driver, road manners are first priority. When I retire, it will transform into a true wheeler. Then I'll add a Trackhawk for road duties.
That is mortifying! Like you, I had no idea that passenger vehicle wheels or tires would reach 30". Sadly, this was popular in Harley world for the front wheel only. Last I checked, they went up to a 32" Harley wheel. To me, anything over 21 or 23" looked silly and out of proportion.Bigger is better...30"to be honest, I didn't realize tires this size even existed.
That’s got to be a bumpy ride . Could you imagine airing down to 12 psiBigger is better...30"to be honest, I didn't realize tires this size even existed.
HOT WHEELS!That is mortifying! Like you, I had no idea that passenger vehicle wheels or tires would reach 30". Sadly, this was popular in Harley world for the front wheel only. Last I checked, they went up to a 32" Harley wheel. To me, anything over 21 or 23" looked silly and out of proportion.
