this is what I used, looks to be the same as your listing.
only because I couldn’t find the amp rating on the Warn kit and all the solenoids that I could find online similar to the Warn were only rated at 300 amps. when I was looking for a solenoid I came across a description for the Warn kit that stated it was not suitable for winches and on the Warn website in the description it says (”Allows you to connect aftermarket accessories to a battery lead and then disconnect power from a dash mounted switch. Recommended for extra protection”) nothing about a winch. It left me with some doubts.
Allows you to connect aftermarket accessories to a battery lead and then disconnect power from a dash mounted switch. Recommended for extra protection.
www.warn.com
at full pull a Warn Zeon 12s can draw up to 469 amps according to the warn website.
