Douno4Sure
- Feb 3, 2022
- 30
- 61
- Current Rides
- 2013 JLU Sahara Dune 2.5” Iift Fastback Softop, 2005 HD Road King
What's the recommendation from this forum on when to do the 1st Oil Change? How many Miles / Time ?
My plan when mine arrives.Jeep 392 manual says every 6 months or at intervals of 10,000 miles, then 20,000 miles, then 30,000 miles etc...
For those who change their own oil, Jeep also recommends these at the first oil change- Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before scheduled maintenance. If using your vehicle for any of the following: dusty or off-road conditions, then inspect the engine air cleaner filter; replace if necessary. Inspect the brake linings; replace if necessary. Inspect the CV/Universal joints.
Our 2 Dr. JL Rubicon gets the oil changed every 3,000Jeep 392 manual says every 6 months or at intervals of 10,000 miles, then 20,000 miles, then 30,000 miles etc...
Our 2dr. JL Rubicon gets an o change every 4000 miles.I did mine at 3399 miles, had been thinking about doing it at around 3k miles. You can see from the pics, the oil has become pretty dark https://www.jeep392.com/threads/my-first-ever-oil-change-and-takeaways.1362/
I thought it was every 6m/ 6k milesJeep 392 manual says every 6 months or at intervals of 10,000 miles, then 20,000 miles, then 30,000 miles etc...
This is my exact same schedule. Should hit 1k this weekend, so will start the process then.My plan when mine arrives.
1000 miles - first oil change. Install magnetic oil drain plug. Mobil 1 decal installed on the back window, lower left corner. All our vehicles get the decal. Wife thinks I'm a little crazy. LOL
4000 miles - oil change.
every 5000 miles - oil change.
Mobil 1 Truck and SUV 0-40w and Napa Gold or Premium oil filter.
Tires rotated every 5000 miles.
It's not just your wife...1000 miles - first oil change. Install magnetic oil drain plug. Mobil 1 decal installed on the back window, lower left corner. All our vehicles get the decal. Wife thinks I'm a little crazy. LOL
