stumblinhorse
I was asked what I thought “needs“ to be upgraded on a 392. I didn’t want to hijack that thread so here is a new thread. These, in my mind, are needs, not just wants. These left as is will cause headaches to you as a Jeep owner. This is not a long list, so nothing that is controversial.
1. Longer or adjustable control arms on front. Because the 392 is the most lifted wrangler from the factory, it needs longer control arms. This should come from the factory, but it doesn’t. Left as is will make the caster be lower than it should be for acceptable handling. Many will say that “my 392 handles great!” My answer is that is because you haven’t driven one with this upgrade…. Even the mopar 2” lift comes with longer control arms. So why the 392 didn’t get them, cost.
2. Fender liners. Unless you drive where there is no atmosphere, like the moon or in space, you will have a problem with the stock fender liners. They will get soft and come in contact with the wheel. That will pretty much destroy them. Again, many will say, “my 392 didn’t have a problem”. If you haven’t it is pure luck.
3. Tpms adjustment. You will need something to lower the factory required 37 psi. 37 psi is too much pressure in any tires that comes on a 392. 392s should be set to about 30 psi cold, depending on how cold is cold in your area
. This will get you to about 35-36 hot psi. That is about as high as you ever want. But setting to 30 cold will trigger the warning until you get back to 37!
strongly recommended upgrade.
1. Steering stabilizer. Ridiculous that they upgrades to better shocks, fox/mopar depending on model But then It has a $5 stabilizer on it. You don’t need to spend $500 on the top of the line. But get something better.
Hope the helps new buyers.
