Washer motor not working
Leslumpy
Boston
JL392 granite
Nearing my 2 month anniversary (about 600miles) and cannot recall using the windshield washer yet, today was the 1st time and nothing, no noise and parked in a heated garage.
Is there a fuse just for the pump, checked out the manual and don’t see one…. Did pop a fuse for the aux ignition connecting up the plow and may have mistakenly move a fuse?
Apparently the wiper fuse and washer pump are 2 different circuits and my luck was to find it 3rd from the last fuse.
Today the washer is not working again and all of the fuses are ok, worked fine for couple weeks when needed. Funny thing, it worked after checking the fuses …… only once.
Air temp?
Factory and dealer fill with standard fluid which can freeze at 25°. Just had this happen to me.
Thawed out and no problem after that.
Our washer pump was DOA once I noticed it wasnt working dealer immediately replaced it.
Air temp?
Heated garage, neither front or back pump works… I guess a dealer trip in a couple days
That sucks
i thought for sure mine failed until it was parked for a few and the lines thawed. Manufacturing and dealers put in the normal mix.
i bled out the OEM mix and replaced with rain-x winter mix (-30° rated). No issues. Yet… 🤞🏼
Up to now it’s been a pavement princess but with a big storm coming Saturday, I’ll be sure to check every button and mode and make sure that it doesn’t have any other problems
Update at the dealer, of coarse it worked for the service manager. when I asked him to try the rear, it didn’t work and then the front now wasn’t working again. They are ordering a new washer pump.
should be quick - when I told my dealer he went ahead and order a pump just in case… it was only a matters of days …so hopefully its quick for u too … cant live without washer pump here in CO
