Been having issues with my transmission for the past week or so. I get a check engine light and every once in a while upon start up reverse gear won't engage until a restart and/or reset trouble codes. Other than that Jeep seems to drive fine with no apparent slipping or shifting issues.
The code I get is P075B-00 'Shift Solenoid G performance/ stuck off'. I remember this code from just over a year ago when I had the same issue and dealer replaced the whole transmission assembly for me under warranty. I'm out of warranty now and looking to see if there are any options to beef up the transmission so it lasts more than a year each time
Found a couple of things on Google that look like they might do the trick -
www.puredrivetrainsolutions.com
dekaclutch.com
I've found a couple of shops here locally who can do the transmission rebuild if I get them the kit
Wanted to see if anyone has any experience with this kind of thing and if you could make any recommendations or point me in the right direction
ZF 8HP75 Transmission Upgrade — Pure Drivetrain Solutions
Our rebuild focuses on fortifying the overall holding power and reliability of your transmission. Through modifications and replacement of oem parts to our own billet parts we are able to achieve the highest clutch counts currently available on the market and the most holding power possible. With ea
BMW ZF 8HP75 Transmission Upgrade
The ZF 8HP75 transmission is an 8-speed automatic transmission developed for various BMW models equipped with N63 and S63 V8 engines, including the F90 M5, F91 M8, G11 750i, and G15 M850i. When enhancing engine performance, it is crucial that the transmission is upgraded as well, ensuring that...
dekaclutch.com
