Tazer Question
392Stinger
W.Tennessee
Is my interpretation of this correct? Holding down traction control for 5 seconds also forces 2WD?
Anyone have experience if that’s accurate or not?
From Tazer instructions:
Full traction control disable (excl. 4XE): Press and hold the traction button for
5 seconds to fully disable TC and ABS (and enter 2WD in the 392. Tap again to restore 4WD.) Shut off and re-start Jeep to
Following
It looks like it did in this video. I did it on mine this morning and it lit disabled all traction control according to screen but did not test 2wd.
Noticed in manual that you can turn fans on by pressing r arrow and cruise cancel. This works great and could be useful while sitting in line idling.
Noticed in manual that you can turn fans on by pressing r arrow and cruise cancel. This works great and could be useful while sitting in line.
Thanks and yes the cool down quick key is there and I’ve used it a couple of times. I need to try the TC hold for 5 seconds to see if it forces 2wd.
If you want 2 wd you can also select it on the cruise control buttons, push to disengage 4 wd or push again to re-engage.
