Tazer Mini
1268
PA
2019 Raptor
Just got mine delivered today and I am going to adjust tire size and tire pressure? What is everyone else using it for? Thinking if I am only using it for that and am considering tghe Livernois tune to return the Tazer unless someone can convince me otherwise.......
I use it to:
Force 2wd so I can run higher HP
Input Navigation while moving
Able to open the driver door at low speeds so it doesnt throw the Jeep in Park
Stop the seatbelt ding
Stop the motor from turning off at the stoplight
View the Rear camera while moving whenever I want especially while towing
Calibrate speedometer
and 20 other things it does that I cant think of right now but the Force2wd alone is worth its weight.
Tazer Mini and Pedal Commander and you will think your 392 was a steal at that price because it is probably the funnest vehicle to drive that I have ever owned and I am in triple digit numbers so that says a lot.
When using the Pedal Commander I highly recommend the Force2wd feature which also increases fuel economy.
Force 2wd.....how can it do that?
I would like to understand how the Force2wd option works as well. Do you have to disable that feature to then use 4wd?? Or can you just pull the handle back and it will override the option setting??
