Sky one touch power top
Captain clap
New member
Cleveland
Jeep 392
I have the sky one touch power top, does anybody experience a little lite coming through towards the front, both passenger and driver when on the highway ?
I haven't noticed, but I'm going to be on the look out for that when I next drive it. Are you getting water intrusion?
nothing on mine as well.. very tight, check the seal for dirt maybe something stuck up there
As @spyder625 said it might be an obstruction. In that case you should get a message on instrument cluster display saying "Power Top Obstacle Detected".
Or it could be an issue with the forward position not seating properly into the weather seal. You could also try recalibrating to top as described in the video below incase it is just out of calibration. But to answer your original question; No, light coming from the front is not normal. But it should be under warranty. ;)👍
