- Nov 5, 2023
- 1,185
- 2,122
- Current Rides
- 2023 Wrangler Rubicon 392, 2024 Wrangler Rubicon X
Yep
Ring and pinion was last week.Time for a new transmission or was it a ring and pinion?
This may be in your future. If my stock tc ever goes this is what I'll replace it with:Ring and pinion was last week.
Yep, I said from day 1 that I am will to go through 2 TCs before going to an Atlas.This may be in your future. If my stock tc ever goes this is what I'll replace it with:
Atlas Transfer Case Jeep JL 2SP Builder
Configure the Atlas Transfer Case for your Jeep JL & JT Model Wranglerwww.advanceadapters.com
Best of luck!
Tazer isn't a big deal and I have never had an issue with the one in my Jeep or TRX.10 miles into my 2nd TC now... looking into Atlas as well just in case... Looks like a very big job though and with less than perfect end results? I don't want to have to resort to Jscan, tazer and all just to get the Jeep to run properly with 4lo, lockers etc. Stellantis really needs to sort this out
yeah, I'm sure tazer's fine. My point was when you spend 100k$ on a vehicle the least you should expect is that essential stuff like the TC will work stock without having to resort to aftermarketTazer isn't a big deal and I have never had an issue with the one in my Jeep or TRX.
That would be awesome.yeah, I'm sure tazer's fine. My point was when you spend 100k$ on a vehicle the least you should expect is that essential stuff like the TC will work stock without having to resort to aftermarket![]()
I concur10 miles into my 2nd TC now... looking into Atlas as well just in case... Looks like a very big job though and with less than perfect end results? I don't want to have to resort to Jscan, tazer and all just to get the Jeep to run properly with 4lo, lockers etc. Stellantis really needs to sort this out
Agree but being a Jeep owner since the early 80's you buy them knowing that almost every single part is going to get replaced if you are going to use it off road....yeah, I'm sure tazer's fine. My point was when you spend 100k$ on a vehicle the least you should expect is that essential stuff like the TC will work stock without having to resort to aftermarket![]()
This 100%.Agree but being a Jeep owner since the early 80's you buy them knowing that almost every single part is going to get replaced if you are going to use it off road....
That sucks, did they replace the TC before?
Better get a lot loto ticket.
