Mr.PoodlePants
- Nov 4, 2024
- 19
- 35
- Current Rides
- 2021 Rubicon 392, 2021 Cadillac Escalade, 2022 BMW M8 Competition, 2023 BMW R1250 GS Adventure, 2017 Ford Raptor, 2014 Harley Road Glide CVO
**Update. jeep home now. The cause of the symptoms below were resolved by the dealer, under warranty by replacing the transmission oil pressure sensor.
2021 stock 392. Just over 15,000 miles. I was gently mudding Sunday evening , the mud was just over the bumper. While moving forward and back in 4wLo with everything locked I got the Service Transmission message on the dash. After extracting myself from the hole, I pulled to the side, took some photos and then left. Upon leaving I soon realized the transmission was not upshifting. I stopped, shutdown and restarted and everything seemed fine. After the ride I hit the car wash and upon leaving I was unable to shift into Reverse. The lever in reverse but the R light would just blink and the Jeep would not move. I put it in Drive and had the same issue with it not shifting. Shut down, restart and went home fine... Next day after a couple attempts to drive I now see a pattern where when the jeep is started, Reverse will not work and Drive will not upshift. Restarting a second time returns everything to normal. I have not seen the Service Transmission warning again but the check engine light remains on and I got an email from our Jeep Overlords stating I had the Service Transmission error and that I should take it to the dealer.
