392OVRLND
Featured
- Thread starter
- #221
I had some time to wrench yesterday, so I decided to install the Borla S-Type cat back exhaust that I purchased from my friend Jackson over at Glendale DCJ. The installation was relatively easy, with just a couple of trickier parts.
If you're ordering this and thinking about tackling it yourself, the most difficult part of the install are:
Also, everything tucks up super nice, so I'm not as worried about smashing the muffler or a tip in the future. Definitely gives you a better departure angle. Borla also revised the exhaust to clear piggyback reservoir shocks; there's plenty of clearance now, as opposed to the early version of the exhaust.
Here's some pics...
- Removing the factory rear muffler from the exhaust hangers; getting to the exhaust hangers and getting leverage on them is a bit of a challenge, especially if working with the Jeep on the ground, so I'd recommend removing the exhaust tips altogether to give yourself additional space to work
- Removing the factory mid-section; getting the mid-section of the exhaust off requires getting it off of two hangers; the front one is EZ-PZ, but the rear one will only come off as the section of the exhaust is pushed backwards, so I'd recommend getting yourself a BFH (like a plastic deadblow mallet) and beating on the front hanger and the bottom edge of the resonators to get the exhaust moving backward, then it will come off (albeit slowly)
- Aligning the Borla rear muffler with the over-axle tubing so that the over-axle tubing will slide into the expanded ends of the tubing coming out of the muffler and getting the hangers back on; get yourself a buddy to help you and prepare to say a lot of "MF'ers" while doing this
Here's some pics...
