Google "load equalizer hitch", that should level out you rig....We just got our 392 and I am afraid the suspension is not enough to tow our off road trailer. Does anyone know of a suspension kit with heavy duty springs?
Your better guess is old, much older than most in this forum. I understand it will handle differently. My 2018 Recon had AEV HC springs with a 4 1/2 lift. I drove much differently also. But we go off road and need a 2-3 inch lift with high capacity springs. ThanksThere's probably a joke about prison britches in there somewhere, or, old age!
But seriously, I feared reality on the softer springs in the rear would result in what you experienced. My concern with putting stiffer springs on the rear axel would totally alter its handling characteristics, since Jeep had to reduce the rear 10% and increase the front 20% just to keep it handling "similar" to the V6 Rubi...
An LE will reduce off road trailering as far as I know.Google "load equalizer hitch", that should level out you rig....
This video explains what a "load leveler" or "weight distributing hitch" doesAn LE will reduce off road trailering as far as I have know.
Thank youThis video explains what a "load leveler" or "weight distributing hitch" does
I just ordered a 5k kit, high hopesAir Bag it. While i have not personally done this with my jeep, you can use airbags to stiffen/level the rear when hauling. https://www.airliftcompany.com/shop/60829/ There are several videos out there of this system getting installed in jeeps.
Fingers crossed, keep us posted as we may all be in the same boat sooner or later!I just ordered a 5k kit, high hopes![]()
Kit is installed and so far its good, just short road test. The install is not as easy as the videos seem to say it is. Those tiny hose clamps are a bear to put on and then attach to the top of air bags inside the spring under the load pads. My fingers are killing me.I just ordered a 5k kit, high hopes![]()
Do not use that kit number for the 392 XR or Final Edition, or any other that came factory with 2" lift and 35" tires. It will be too short. Use the 60926 universal kit.Air Bag it. While i have not personally done this with my jeep, you can use airbags to stiffen/level the rear when hauling. https://www.airliftcompany.com/shop/60829/ There are several videos out there of this system getting installed in jeeps.
What is the 5K kit?I just ordered a 5k kit, high hopes![]()
There is a recent post called Airlift 1000 for XR. It might help you with your issue.We just got our 392 and I am afraid the suspension is not enough to tow our off road trailer. Does anyone know of a suspension kit with heavy duty springs?
